small question stupid is that I can copy the file of golf 150 tdi to put them back on a bora 115 to take advantage of the power saw that the 2 are injector pump and depourvu of turbine has geometrie variable Piccole questione stupido è che posso copiare il file del Golf 150 TDI di metterli su una Bora 115 di approfittare del potere vide che 2 sono iniettore pompa e depourvu della turbina è rappresentata variabile thank you
You cannot just copy a file of a car into the ecu of another car... it will work only if the two cars and ECUs are EXACTLY the same. I mean the SW and HW code must be the same and it cannot be if the cars are so different. you will brick the ecu...
thanks to its information that I debute seen in this area could tell me what would be the main parametre has increase afinde win of the power of one order of 15%
would you have a trick to its reconaitre 2 paramettre in winols I file has the damos following the what choose for the bora : EDC 15 c EDC 15 p EDC 15 v VAG 115PS TDI PDdbf VAG 1.9 EDC15P1 - dbf+dam VAG 1.9 EDC15P1 VAG 1.9 EDC15P2 VAG 1.9 EDC15P2-dam
