Megane Immo Off Bosch 0 281001969
Ospite victormarinho67
 good day. Help me please! I replaced the eprom 24C02 24C04 and copied a file joined immo off pin 7 to pin 8 and cut the pin 59.
The car started the first time after not pulled over, then I removed the eprom and the car always starts but does not pass 3000 rpm. Now I bought a Renault imulator changed the eprom data to imultor, soldered the three wires but the car does not work nor the first does not work. The first time welding wires imulator was with pdf (carlabimmo) the second time was with pdf ecutool. But the car will not start. PLEASE HELP
megane td 24cl02.rar
salve devi prendere una e2prom nuova 24c16 al posto di quella ori che e la 24c04 e carichi il fail postato mio quando la saldi devi sollevare il pin 7 e collegarlo a ponte con il pin 8 iriferimento pin 8 si trova lato opposto del pin 1 dove ce il bichetto e tagli il filo dell immo. pin 59 o stacchi il pacco code dal blocchetto chiavi monti la ecu e stai apposto
no code tot.rar
giorno amio bene, grazie ;-)
