PHP Version 8.1.30 |
System | Linux node36006-etpsolutions.it1.eur.aruba.jenv-aruba.cloud 5.14.0 #1 SMP Wed Jul 12 12:00:44 MSK 2023 x86_64 |
Build Date | Sep 27 2024 12:51:38 |
Build System | Linux buildkitsandbox 5.4.0 #1 SMP Tue Jan 9 19:45:01 MSK 2024 x86_64 x86_64 x86_64 GNU/Linux |
Configure Command | './configure' '--bindir=/usr/bin' '--build=x86_64-redhat-linux-gnu' '--disable-debug' '--disable-rpath' '--enable-bcmath=shared' '--enable-calendar=shared' '--enable-dba=shared' '--enable-dom=shared' '--enable-exif=shared' '--enable-fileinfo=shared' '--enable-ftp=shared' '--enable-fpm' '--enable-gd=shared' '--enable-gd-native-ttf' '--enable-json=shared' '--enable-libxml' '--enable-mbstring=shared,all' '--enable-mysqlnd=shared' '--enable-pcntl=shared' '--enable-pdo=shared' '--enable-phar=shared' '--enable-posix=shared' '--enable-shared' '--enable-shmop=shared' '--enable-simplexml=shared' '--enable-soap=shared' '--enable-sockets' '--enable-sysvsem=shared' '--enable-sysvshm=shared' '--enable-tokenizer=shared' '--enable-wddx=shared' '--enable-xml' '--enable-xmlreader=shared' '--enable-xmlwriter=shared' '--enable-zip=shared' '--exec-prefix=/usr' '--host=x86_64-redhat-linux-gnu' '--libdir=/usr/lib64' '--prefix=/usr' '--program-prefix=' '--sbindir=/usr/sbin' '--target=x86_64-redhat-linux-gnu' '--with-apxs2=/bin/apxs' '--with-bz2=shared' '--with-config-file-path=/etc' '--with-config-file-scan-dir=/etc/php.d' '--with-ctype=shared' '--with-curl=shared' '--with-freetype' '--with-freetype-dir=/usr' '--with-freetype-dir=/usr/include/freetype2/freetype' '--with-gd=shared' '--with-gettext=shared' '--with-gmp=shared' '--with-iconv=shared' '--with-imap=shared' '--with-imap-ssl' '--with-jpeg-dir' '--with-jpeg-dir=/usr' '--with-kerberos' '--with-layout=GNU' '--with-ldap=shared' '--with-libdir=lib64' '--with-libxml-dir=/usr' '--with-mhash' '--with-mysqli=shared' '--with-mysql=shared' '--with-openssl=shared' '--without-gdbm' '--without-sqlite' '--with-password-argon2' '--with-pdo-firebird=shared' '--with-pdo-mysql=shared' '--with-pdo-pgsql=shared,/usr/pgsql-13' '--with-pdo-sqlite=shared,/usr' '--with-pear' '--with-pgsql=shared,/usr/pgsql-13' '--with-pic' '--with-png-dir' '--with-png-dir=/usr' '--with-pspell=shared' '--with-snmp=shared' '--with-sqlite3=shared' '--with-tidy=shared' '--with-unixODBC=shared,/usr' '--with-webp-dir=/usr/include/webp' '--with-xmlrpc=shared' '--with-xpm-dir' '--with-xsl=shared' '--with-zlib-dir' '--with-zlib=shared' '--enable-zts' 'build_alias=x86_64-redhat-linux-gnu' 'host_alias=x86_64-redhat-linux-gnu' 'target_alias=x86_64-redhat-linux-gnu' |
Server API | Apache 2.0 Handler |
Virtual Directory Support | enabled |
Configuration File (php.ini) Path | /etc |
Loaded Configuration File | /etc/php.ini |
Scan this dir for additional .ini files | /etc/php.d |
Additional .ini files parsed | /etc/php.d/error-log.ini |
PHP API | 20210902 |
PHP Extension | 20210902 |
Zend Extension | 420210902 |
Zend Extension Build | API420210902,TS |
PHP Extension Build | API20210902,TS |
Debug Build | no |
Thread Safety | enabled |
Thread API | POSIX Threads |
Zend Signal Handling | enabled |
Zend Memory Manager | enabled |
Zend Multibyte Support | provided by mbstring |
Zend Max Execution Timers | disabled |
IPv6 Support | enabled |
DTrace Support | disabled |
Registered PHP Streams | php, file, glob, data, http, ftp, compress.bzip2, https, ftps, compress.zlib, zip, phar |
Registered Stream Socket Transports | tcp, udp, unix, udg, ssl, tls, tlsv1.0, tlsv1.1, tlsv1.2, tlsv1.3 |
Registered Stream Filters | string.rot13, string.toupper, string.tolower, convert.*, consumed, dechunk, bzip2.*, convert.iconv.*, mcrypt.*, mdecrypt.*, zlib.* |
This program makes use of the Zend Scripting Language Engine: Zend Engine v4.1.30, Copyright (c) Zend Technologies |
Apache Version | Apache |
Apache API Version | 20120211 |
Server Administrator | admin@etpsolutions.com |
Hostname:Port | www.etpsolutions.com:443 |
User/Group | apache(700)/700 |
Max Requests | Per Child: 500 - Keep Alive: off - Max Per Connection: 100 |
Timeouts | Connection: 120 - Keep-Alive: 15 |
Virtual Server | Yes |
Server Root | /etc/httpd |
Loaded Modules | core mod_so http_core mod_access_compat mod_actions mod_alias mod_allowmethods mod_auth_basic mod_auth_digest mod_authn_anon mod_authn_core mod_authn_dbd mod_authn_dbm mod_authn_file mod_authn_socache mod_authnz_fcgi mod_authz_core mod_authz_dbd mod_authz_dbm mod_authz_groupfile mod_authz_host mod_authz_owner mod_authz_user mod_autoindex mod_cache mod_cache_disk mod_cache_socache mod_data mod_dbd mod_deflate mod_dir mod_dumpio mod_echo mod_env mod_expires mod_ext_filter mod_filter mod_headers mod_include mod_info mod_log_config mod_logio mod_macro mod_mime_magic mod_mime mod_negotiation mod_remoteip mod_reqtimeout mod_request mod_rewrite mod_setenvif mod_slotmem_plain mod_slotmem_shm mod_socache_dbm mod_socache_memcache mod_socache_redis mod_socache_shmcb mod_status mod_substitute mod_suexec mod_unique_id mod_unixd mod_userdir mod_version mod_vhost_alias mod_watchdog mod_dav mod_dav_fs mod_dav_lock mod_lua prefork mod_proxy mod_lbmethod_bybusyness mod_lbmethod_byrequests mod_lbmethod_bytraffic mod_lbmethod_heartbeat mod_proxy_ajp mod_proxy_balancer mod_proxy_connect mod_proxy_express mod_proxy_fcgi mod_proxy_fdpass mod_proxy_ftp mod_proxy_http mod_proxy_hcheck mod_proxy_scgi mod_proxy_uwsgi mod_proxy_wstunnel mod_systemd mod_cgi mod_realdoc mod_usertrack mod_speling mod_asis mod_ssl mod_php mod_http2 |
Directive | Local Value | Master Value |
engine | On | On |
last_modified | Off | Off |
xbithack | Off | Off |
Variable | Value |
REDIRECT_UNIQUE_ID | Z0D77rRPX_MlEOJM5ag9LwAAAAU |
REDIRECT_HTTPS | on |
REDIRECT_SSL_TLS_SNI | etpsolutions.com |
REDIRECT_STATUS | 200 |
HTTPS | on |
HTTP_ACCEPT | */* |
HTTP_USER_AGENT | Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com) |
HTTP_COOKIE | handl_url=https%3A%2F%2Fswift-cut.com%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F; RWSESSID=92bc1687ebe8b272695001d39b417ec7; handl_ip=3.144.103.20; handl_ref=https%3A%2F%2Fswift-cut.com%2Fde%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F%3Fwg-choose-original%3Dfalse; HandLtestDomainNameServer=HandLtestDomainValueServer; handl_url_base=https%3A%2F%2Fswift-cut.com%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F; handl_original_ref=https%3A%2F%2Fswift-cut.com%2Fde%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F%3Fwg-choose-original%3Dfalse; handl_landing_page=https%3A%2F%2Fswift-cut.com%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F; organic_source=https%3A%2F%2Fswift-cut.com%2Fde%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F%3Fwg-choose-original%3Dfalse; user_agent=Mozilla%2F5.0%20AppleWebKit%2F537.36%20%28KHTML%2C%20like%20Gecko%3B%20compatible%3B%20ClaudeBot%2F1.0%3B%20%2Bclaudebot%40anthropic.com%29; organic_source_str=Internal |
HTTP_ACCEPT_ENCODING | gzip, br, zstd, deflate |
HTTP_HOST | etpsolutions.com |
PATH | /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin |
SERVER_SIGNATURE | no value |
SERVER_SOFTWARE | Apache |
SERVER_NAME | etpsolutions.com |
SERVER_ADDR | 95.110.177.123 |
SERVER_PORT | 443 |
REMOTE_ADDR | 3.144.103.20 |
DOCUMENT_ROOT | /var/www/webroot/ROOT |
REQUEST_SCHEME | https |
CONTEXT_PREFIX | no value |
CONTEXT_DOCUMENT_ROOT | /var/www/webroot/ROOT |
SERVER_ADMIN | admin@etpsolutions.com |
SCRIPT_FILENAME | /var/www/webroot/ROOT/index.php |
REMOTE_PORT | 12133 |
REDIRECT_URL | /forums/topic/33189-aiuto-clonare-ecu-13-m-jet/ |
REDIRECT_QUERY_STRING | comment=237668&do=findComment |
GATEWAY_INTERFACE | CGI/1.1 |
SERVER_PROTOCOL | HTTP/1.1 |
REQUEST_METHOD | GET |
REQUEST_URI | /forums/topic/33189-aiuto-clonare-ecu-13-m-jet/?comment=237668&do=findComment |
SCRIPT_NAME | /index.php |
HTTP Request Headers | |
HTTP Request | GET /forums/topic/33189-aiuto-clonare-ecu-13-m-jet/?comment=237668&do=findComment HTTP/1.1 |
accept | */* |
user-agent | Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com) |
cookie | handl_url=https%3A%2F%2Fswift-cut.com%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F; RWSESSID=92bc1687ebe8b272695001d39b417ec7; handl_ip=3.144.103.20; handl_ref=https%3A%2F%2Fswift-cut.com%2Fde%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F%3Fwg-choose-original%3Dfalse; HandLtestDomainNameServer=HandLtestDomainValueServer; handl_url_base=https%3A%2F%2Fswift-cut.com%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F; handl_original_ref=https%3A%2F%2Fswift-cut.com%2Fde%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F%3Fwg-choose-original%3Dfalse; handl_landing_page=https%3A%2F%2Fswift-cut.com%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F; organic_source=https%3A%2F%2Fswift-cut.com%2Fde%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F%3Fwg-choose-original%3Dfalse; user_agent=Mozilla%2F5.0%20AppleWebKit%2F537.36%20%28KHTML%2C%20like%20Gecko%3B%20compatible%3B%20ClaudeBot%2F1.0%3B%20%2Bclaudebot%40anthropic.com%29; organic_source_str=Internal |
accept-encoding | gzip, br, zstd, deflate |
host | etpsolutions.com |
HTTP Response Headers | |
Upgrade | h2 |
Connection | Upgrade |
BCMath support | enabled |
bcmath.scale | 0 | 0 |
BZip2 Support | Enabled |
Stream Wrapper support | compress.bzip2:// |
Stream Filter support | bzip2.decompress, bzip2.compress |
BZip2 Version | 1.0.8, 13-Jul-2019 |
Calendar support | enabled |
PHP Version | 8.1.30 |
allow_url_fopen | On | On |
allow_url_include | Off | Off |
arg_separator.input | & | & |
arg_separator.output | & | & |
auto_append_file | no value | no value |
auto_globals_jit | On | On |
auto_prepend_file | no value | no value |
browscap | no value | no value |
default_charset | UTF-8 | UTF-8 |
default_mimetype | text/html | text/html |
disable_classes | no value | no value |
disable_functions | no value | no value |
display_errors | Off | Off |
display_startup_errors | Off | Off |
doc_root | no value | no value |
docref_ext | no value | no value |
docref_root | no value | no value |
enable_dl | Off | Off |
enable_post_data_reading | On | On |
error_append_string | no value | no value |
error_log | /var/log/httpd/php_errors.log | /var/log/httpd/php_errors.log |
error_prepend_string | no value | no value |
error_reporting | 32767 | 32767 |
expose_php | Off | Off |
extension_dir | /usr/lib64/php/modules | /usr/lib64/php/modules |
fiber.stack_size | no value | no value |
file_uploads | On | On |
hard_timeout | 2 | 2 |
highlight.comment | #FF8000 | #FF8000 |
highlight.default | #0000BB | #0000BB |
highlight.html | #000000 | #000000 |
highlight.keyword | #007700 | #007700 |
highlight.string | #DD0000 | #DD0000 |
html_errors | On | On |
ignore_repeated_errors | On | On |
ignore_repeated_source | On | On |
ignore_user_abort | On | On |
implicit_flush | Off | Off |
include_path | .:/usr/share/pear | .:/usr/share/pear |
input_encoding | no value | no value |
internal_encoding | no value | no value |
log_errors | On | On |
mail.add_x_header | On | On |
mail.force_extra_parameters | no value | no value |
mail.log | /var/log/httpd/sendmail.log | /var/log/httpd/sendmail.log |
max_execution_time | 300 | 300 |
max_file_uploads | 20 | 20 |
max_input_nesting_level | 64 | 64 |
max_input_time | 60 | 60 |
max_input_vars | 1000 | 1000 |
max_multipart_body_parts | -1 | -1 |
memory_limit | 256M | 256M |
open_basedir | no value | no value |
output_buffering | 4096 | 4096 |
output_encoding | no value | no value |
output_handler | no value | no value |
post_max_size | 100M | 100M |
precision | 14 | 14 |
realpath_cache_size | 4096K | 4096K |
realpath_cache_ttl | 120 | 120 |
register_argc_argv | On | On |
report_memleaks | On | On |
report_zend_debug | Off | Off |
request_order | GP | GP |
sendmail_from | no value | no value |
sendmail_path | /usr/sbin/sendmail -t -i | /usr/sbin/sendmail -t -i |
serialize_precision | 17 | 17 |
short_open_tag | On | On |
SMTP | localhost | localhost |
smtp_port | 25 | 25 |
sys_temp_dir | no value | no value |
syslog.facility | LOG_USER | LOG_USER |
syslog.filter | no-ctrl | no-ctrl |
syslog.ident | php | php |
unserialize_callback_func | no value | no value |
upload_max_filesize | 100M | 100M |
upload_tmp_dir | no value | no value |
user_dir | no value | no value |
user_ini.cache_ttl | 300 | 300 |
user_ini.filename | .user.ini | .user.ini |
variables_order | GPCS | GPCS |
xmlrpc_error_number | 0 | 0 |
xmlrpc_errors | Off | Off |
zend.assertions | 1 | 1 |
zend.detect_unicode | On | On |
zend.enable_gc | On | On |
zend.exception_ignore_args | Off | Off |
zend.exception_string_param_max_len | 15 | 15 |
zend.multibyte | Off | Off |
zend.script_encoding | no value | no value |
zend.signal_check | Off | Off |
ctype functions | enabled |
cURL support | enabled |
cURL Information | 7.76.1 |
Age | 8 |
Features | |
AsynchDNS | Yes |
CharConv | No |
Debug | No |
GSS-Negotiate | No |
IDN | No |
IPv6 | Yes |
krb4 | No |
Largefile | Yes |
libz | Yes |
NTLM | Yes |
NTLMWB | No |
SPNEGO | Yes |
SSL | Yes |
SSPI | No |
TLS-SRP | No |
HTTP2 | Yes |
GSSAPI | Yes |
KERBEROS5 | Yes |
UNIX_SOCKETS | Yes |
PSL | No |
HTTPS_PROXY | Yes |
MULTI_SSL | No |
BROTLI | No |
Protocols | file, ftp, ftps, http, https |
Host | x86_64-redhat-linux-gnu |
SSL Version | OpenSSL/3.0.7 |
ZLib Version | 1.2.11 |
curl.cainfo | no value | no value |
date/time support | enabled |
timelib version | 2021.19 |
"Olson" Timezone Database Version | 2023.3 |
Timezone Database | internal |
Default timezone | UTC |
date.default_latitude | 31.7667 | 31.7667 |
date.default_longitude | 35.2333 | 35.2333 |
date.sunrise_zenith | 90.833333 | 90.833333 |
date.sunset_zenith | 90.833333 | 90.833333 |
date.timezone | UTC | UTC |
DBA support | enabled |
Supported handlers | cdb cdb_make inifile flatfile |
dba.default_handler | flatfile | flatfile |
DOM/XML | enabled |
DOM/XML API Version | 20031129 |
libxml Version | 2.9.13 |
HTML Support | enabled |
XPath Support | enabled |
XPointer Support | enabled |
Schema Support | enabled |
RelaxNG Support | enabled |
EXIF Support | enabled |
Supported EXIF Version | 0220 |
Supported filetypes | JPEG, TIFF |
Multibyte decoding support using mbstring | enabled |
Extended EXIF tag formats | Canon, Casio, Fujifilm, Nikon, Olympus, Samsung, Panasonic, DJI, Sony, Pentax, Minolta, Sigma, Foveon, Kyocera, Ricoh, AGFA, Epson |
exif.decode_jis_intel | JIS | JIS |
exif.decode_jis_motorola | JIS | JIS |
exif.decode_unicode_intel | UCS-2LE | UCS-2LE |
exif.decode_unicode_motorola | UCS-2BE | UCS-2BE |
exif.encode_jis | no value | no value |
exif.encode_unicode | ISO-8859-15 | ISO-8859-15 |
fileinfo support | enabled |
libmagic | 540 |
Input Validation and Filtering | enabled |
filter.default | unsafe_raw | unsafe_raw |
filter.default_flags | no value | no value |
FTP support | enabled |
FTPS support | enabled |
GetText Support | enabled |
gmp support | enabled |
GMP version | 6.2.0 |
hash support | enabled |
Hashing Engines | md2 md4 md5 sha1 sha224 sha256 sha384 sha512/224 sha512/256 sha512 sha3-224 sha3-256 sha3-384 sha3-512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost gost-crypto adler32 crc32 crc32b crc32c fnv132 fnv1a32 fnv164 fnv1a64 joaat murmur3a murmur3c murmur3f xxh32 xxh64 xxh3 xxh128 haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5 |
MHASH support | Enabled |
MHASH API Version | Emulated Support |
iconv support | enabled |
iconv implementation | glibc |
iconv library version | 2.34 |
iconv.input_encoding | no value | no value |
iconv.internal_encoding | no value | no value |
iconv.output_encoding | no value | no value |
json support | enabled |
libXML support | active |
libXML Compiled Version | 2.9.13 |
libXML Loaded Version | 20913 |
libXML streams | enabled |
Multibyte Support | enabled |
Multibyte string engine | libmbfl |
HTTP input encoding translation | enabled |
libmbfl version | 1.3.2 |
mbstring extension makes use of "streamable kanji code filter and converter", which is distributed under the GNU Lesser General Public License version 2.1. |
Multibyte (japanese) regex support | enabled |
Multibyte regex (oniguruma) version | 6.9.6 |
mbstring.detect_order | no value | no value |
mbstring.encoding_translation | On | On |
mbstring.http_input | no value | no value |
mbstring.http_output | no value | no value |
mbstring.http_output_conv_mimetypes | ^(text/|application/xhtml\+xml) | ^(text/|application/xhtml\+xml) |
mbstring.internal_encoding | no value | no value |
mbstring.language | Neutral | Neutral |
mbstring.regex_retry_limit | 1000000 | 1000000 |
mbstring.regex_stack_limit | 100000 | 100000 |
mbstring.strict_detection | Off | Off |
mbstring.substitute_character | no value | no value |
mcrypt support | enabled |
mcrypt_filter support | enabled |
Extension version | 1.0.7 |
Library version | 2.5.8 |
Api No | 20021217 |
Supported ciphers | cast-128 gost rijndael-128 twofish arcfour cast-256 loki97 rijndael-192 saferplus wake blowfish-compat des rijndael-256 serpent xtea blowfish enigma rc2 tripledes |
Supported modes | cbc cfb ctr ecb ncfb nofb ofb stream |
mcrypt.algorithms_dir | no value | no value |
mcrypt.modes_dir | no value | no value |
memcached support | enabled |
Version | 3.2.0 |
libmemcached-awesome version | 1.1.0 |
SASL support | yes |
Session support | yes |
igbinary support | no |
json support | no |
msgpack support | no |
memcached.compression_factor | 1.3 | 1.3 |
memcached.compression_threshold | 2000 | 2000 |
memcached.compression_type | fastlz | fastlz |
memcached.default_binary_protocol | Off | Off |
memcached.default_connect_timeout | 0 | 0 |
memcached.default_consistent_hash | Off | Off |
memcached.serializer | php | php |
memcached.sess_binary_protocol | On | On |
memcached.sess_connect_timeout | 1000 | 1000 |
memcached.sess_consistent_hash | On | On |
memcached.sess_consistent_hash_type | ketama | ketama |
memcached.sess_lock_expire | 0 | 0 |
memcached.sess_lock_max_wait | not set | not set |
memcached.sess_lock_retries | 5 | 5 |
memcached.sess_lock_wait | not set | not set |
memcached.sess_lock_wait_max | 150 | 150 |
memcached.sess_lock_wait_min | 150 | 150 |
memcached.sess_locking | On | On |
memcached.sess_number_of_replicas | 0 | 0 |
memcached.sess_persistent | Off | Off |
memcached.sess_prefix | memc.sess.key. | memc.sess.key. |
memcached.sess_randomize_replica_read | Off | Off |
memcached.sess_remove_failed_servers | Off | Off |
memcached.sess_sasl_password | no value | no value |
memcached.sess_sasl_username | no value | no value |
memcached.sess_server_failure_limit | 0 | 0 |
memcached.store_retry_count | 2 | 2 |
MysqlI Support | enabled |
Client API library version | mysqlnd 8.1.30 |
Active Persistent Links | 0 |
Inactive Persistent Links | 0 |
Active Links | 0 |
mysqli.allow_local_infile | Off | Off |
mysqli.allow_persistent | On | On |
mysqli.default_host | no value | no value |
mysqli.default_port | 3306 | 3306 |
mysqli.default_pw | no value | no value |
mysqli.default_socket | no value | no value |
mysqli.default_user | no value | no value |
mysqli.local_infile_directory | no value | no value |
mysqli.max_links | Unlimited | Unlimited |
mysqli.max_persistent | Unlimited | Unlimited |
mysqli.reconnect | Off | Off |
mysqli.rollback_on_cached_plink | Off | Off |
mysqlnd | enabled |
Version | mysqlnd 8.1.30 |
Compression | supported |
core SSL | supported |
extended SSL | supported |
Command buffer size | 4096 |
Read buffer size | 32768 |
Read timeout | 31536000 |
Collecting statistics | Yes |
Collecting memory statistics | Yes |
Tracing | no value |
Loaded plugins | mysqlnd,debug_trace,auth_plugin_mysql_native_password,auth_plugin_mysql_clear_password,auth_plugin_caching_sha2_password,auth_plugin_sha256_password |
API Extensions | mysqli,pdo_mysql |
OpenSSL support | enabled |
OpenSSL Library Version | OpenSSL 3.0.7 1 Nov 2022 |
OpenSSL Header Version | OpenSSL 3.0.7 1 Nov 2022 |
Openssl default config | /etc/pki/tls/openssl.cnf |
openssl.cafile | no value | no value |
openssl.capath | no value | no value |
pcntl support | enabled |
PCRE (Perl Compatible Regular Expressions) Support | enabled |
PCRE Library Version | 10.39 2021-10-29 |
PCRE Unicode Version | 14.0.0 |
PCRE JIT Support | enabled |
PCRE JIT Target | x86 64bit (little endian + unaligned) |
pcre.backtrack_limit | 1000000 | 1000000 |
pcre.jit | 1 | 1 |
pcre.recursion_limit | 100000 | 100000 |
PDO support | enabled |
PDO drivers | firebird, mysql, pgsql, sqlite |
PDO Driver for Firebird | enabled |
Client Library Version | LI-V6.3.0.2496 Firebird 4.0 |
PDO Driver for MySQL | enabled |
Client API version | mysqlnd 8.1.30 |
pdo_mysql.default_socket | /var/lib/mysql/mysql.sock | /var/lib/mysql/mysql.sock |
PDO Driver for PostgreSQL | enabled |
PostgreSQL(libpq) Version | 13.16 |
PDO Driver for SQLite 3.x | enabled |
SQLite Library | 3.34.1 |
Phar: PHP Archive support | enabled |
Phar API version | 1.1.1 |
Phar-based phar archives | enabled |
Tar-based phar archives | enabled |
ZIP-based phar archives | enabled |
gzip compression | enabled |
bzip2 compression | enabled |
Phar based on pear/PHP_Archive, original concept by Davey Shafik. Phar fully realized by Gregory Beaver and Marcus Boerger. Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle. |
phar.cache_list | no value | no value |
phar.readonly | On | On |
phar.require_hash | On | On |
POSIX support | enabled |
PSpell Support | enabled |
Resource and persistent handle factory support | enabled |
Extension version | 2.0.1 |
Persistent handles in this thread | |||
Provider | Ident | Used | Free |
raphf.persistent_handle.limit | -1 | -1 |
Reflection | enabled |
Session Support | enabled |
Registered save handlers | files user memcached |
Registered serializer handlers | php_serialize php php_binary |
session.auto_start | Off | Off |
session.cache_expire | 180 | 180 |
session.cache_limiter | nocache | nocache |
session.cookie_domain | no value | no value |
session.cookie_httponly | no value | no value |
session.cookie_lifetime | 0 | 0 |
session.cookie_path | / | / |
session.cookie_samesite | no value | no value |
session.cookie_secure | 0 | 0 |
session.gc_divisor | 1000 | 1000 |
session.gc_maxlifetime | 1440 | 1440 |
session.gc_probability | 1 | 1 |
session.lazy_write | On | On |
session.name | PHPSESSID | PHPSESSID |
session.referer_check | no value | no value |
session.save_handler | memcached | memcached |
session.save_path | 172.16.107.229:11211 | 172.16.107.229:11211 |
session.serialize_handler | php | php |
session.sid_bits_per_character | 4 | 4 |
session.sid_length | 32 | 32 |
session.upload_progress.cleanup | On | On |
session.upload_progress.enabled | On | On |
session.upload_progress.freq | 1% | 1% |
session.upload_progress.min_freq | 1 | 1 |
session.upload_progress.name | PHP_SESSION_UPLOAD_PROGRESS | PHP_SESSION_UPLOAD_PROGRESS |
session.upload_progress.prefix | upload_progress_ | upload_progress_ |
session.use_cookies | 1 | 1 |
session.use_only_cookies | 1 | 1 |
session.use_strict_mode | no value | no value |
session.use_trans_sid | 0 | 0 |
shmop support | enabled |
SimpleXML support | enabled |
Schema support | enabled |
Sockets Support | enabled |
SPL support | enabled |
Interfaces | OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject |
Classes | AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, CallbackFilterIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveCallbackFilterIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException |
SQLite3 support | enabled |
sqlite3.defensive | On | On |
sqlite3.extension_dir | no value | no value |
Dynamic Library Support | enabled |
Path to sendmail | /usr/sbin/sendmail -t -i |
assert.active | On | On |
assert.bail | Off | Off |
assert.callback | no value | no value |
assert.exception | On | On |
assert.warning | On | On |
auto_detect_line_endings | Off | Off |
default_socket_timeout | 60 | 60 |
session.trans_sid_hosts | no value | no value |
session.trans_sid_tags | a=href,area=href,frame=src,form= | a=href,area=href,frame=src,form= |
unserialize_max_depth | 4096 | 4096 |
url_rewriter.hosts | no value | no value |
url_rewriter.tags | a=href,area=href,frame=src,input=src,form=fakeentry | a=href,area=href,frame=src,input=src,form=fakeentry |
user_agent | PHP | PHP |
sysvsem support | enabled |
sysvshm support | enabled |
Tidy support | enabled |
libTidy Version | 5.8.0 |
libTidy Release | 2021/07/10 |
tidy.clean_output | 0 | 0 |
tidy.default_config | no value | no value |
Tokenizer Support | enabled |
XML Support | active |
XML Namespace Support | active |
libxml2 Version | 2.9.13 |
XMLReader | enabled |
XMLWriter | enabled |
Zip | enabled |
Zip version | 1.19.5 |
Libzip version | 1.7.3 |
BZIP2 compression | Yes |
XZ compression | Yes |
ZSTD compression | No |
AES-128 encryption | Yes |
AES-192 encryption | Yes |
AES-256 encryption | Yes |
ZLib Support | enabled |
Stream Wrapper | compress.zlib:// |
Stream Filter | zlib.inflate, zlib.deflate |
Compiled Version | 1.2.11 |
Linked Version | 1.2.11 |
zlib.output_compression | Off | Off |
zlib.output_compression_level | -1 | -1 |
zlib.output_handler | no value | no value |
Module Name |
Variable | Value |
LANG | en_US.UTF-8 |
NOTIFY_SOCKET | /run/systemd/notify |
INVOCATION_ID | 79fe95a015f04ec8b103a360df444fa4 |
JOURNAL_STREAM | 8:2444877439 |
SYSTEMD_EXEC_PID | 4711 |
OPENSSL_NO_DEFAULT_ZLIB | 1 |
APACHE_VERSION | 2.4.62 |
CACHE_MEM_LIMIT | 10% |
DOCKER_EXPOSED_PORT | 21,22,25,443,7979,80 |
OWASP_MODSECURITY_CRS_VERSION | 3.3.2 |
PHP_MAX_EXECUTION_TIME | 300 |
PHP_MEMORY_LIMIT | 25% |
PHP_MINOR_VERSION | 8.1 |
PHP_VERSION | 8.1.30 |
REDIS_ENABLED | FALSE |
REDIS_VERSION | 6.2.14 |
WEBROOT | /var/www/webroot |
MASTER_IP | 172.16.108.62 |
MASTER_ID | 36006 |
MASTER_HOST | node36006 |
Variable | Value |
$_REQUEST['comment'] | 237668 |
$_REQUEST['do'] | findComment |
$_GET['comment'] | 237668 |
$_GET['do'] | findComment |
$_COOKIE['handl_url'] | https://swift-cut.com/2017/07/affordable-plasma-cutter/4/ |
$_COOKIE['RWSESSID'] | 92bc1687ebe8b272695001d39b417ec7 |
$_COOKIE['handl_ip'] | 3.144.103.20 |
$_COOKIE['handl_ref'] | https://swift-cut.com/de/2017/07/affordable-plasma-cutter/4/?wg-choose-original=false |
$_COOKIE['HandLtestDomainNameServer'] | HandLtestDomainValueServer |
$_COOKIE['handl_url_base'] | https://swift-cut.com/2017/07/affordable-plasma-cutter/4/ |
$_COOKIE['handl_original_ref'] | https://swift-cut.com/de/2017/07/affordable-plasma-cutter/4/?wg-choose-original=false |
$_COOKIE['handl_landing_page'] | https://swift-cut.com/2017/07/affordable-plasma-cutter/4/ |
$_COOKIE['organic_source'] | https://swift-cut.com/de/2017/07/affordable-plasma-cutter/4/?wg-choose-original=false |
$_COOKIE['user_agent'] | Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com) |
$_COOKIE['organic_source_str'] | Internal |
$_SERVER['REDIRECT_UNIQUE_ID'] | Z0D77rRPX_MlEOJM5ag9LwAAAAU |
$_SERVER['REDIRECT_HTTPS'] | on |
$_SERVER['REDIRECT_SSL_TLS_SNI'] | etpsolutions.com |
$_SERVER['REDIRECT_STATUS'] | 200 |
$_SERVER['UNIQUE_ID'] | Z0D77rRPX_MlEOJM5ag9LwAAAAU |
$_SERVER['HTTPS'] | on |
$_SERVER['SSL_TLS_SNI'] | etpsolutions.com |
$_SERVER['HTTP_ACCEPT'] | */* |
$_SERVER['HTTP_USER_AGENT'] | Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com) |
$_SERVER['HTTP_COOKIE'] | handl_url=https%3A%2F%2Fswift-cut.com%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F; RWSESSID=92bc1687ebe8b272695001d39b417ec7; handl_ip=3.144.103.20; handl_ref=https%3A%2F%2Fswift-cut.com%2Fde%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F%3Fwg-choose-original%3Dfalse; HandLtestDomainNameServer=HandLtestDomainValueServer; handl_url_base=https%3A%2F%2Fswift-cut.com%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F; handl_original_ref=https%3A%2F%2Fswift-cut.com%2Fde%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F%3Fwg-choose-original%3Dfalse; handl_landing_page=https%3A%2F%2Fswift-cut.com%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F; organic_source=https%3A%2F%2Fswift-cut.com%2Fde%2F2017%2F07%2Faffordable-plasma-cutter%2F4%2F%3Fwg-choose-original%3Dfalse; user_agent=Mozilla%2F5.0%20AppleWebKit%2F537.36%20%28KHTML%2C%20like%20Gecko%3B%20compatible%3B%20ClaudeBot%2F1.0%3B%20%2Bclaudebot%40anthropic.com%29; organic_source_str=Internal |
$_SERVER['HTTP_ACCEPT_ENCODING'] | gzip, br, zstd, deflate |
$_SERVER['HTTP_HOST'] | etpsolutions.com |
$_SERVER['PATH'] | /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin |
$_SERVER['SERVER_SIGNATURE'] | no value |
$_SERVER['SERVER_SOFTWARE'] | Apache |
$_SERVER['SERVER_NAME'] | etpsolutions.com |
$_SERVER['SERVER_ADDR'] | 95.110.177.123 |
$_SERVER['SERVER_PORT'] | 443 |
$_SERVER['REMOTE_ADDR'] | 3.144.103.20 |
$_SERVER['DOCUMENT_ROOT'] | /var/www/webroot/ROOT |
$_SERVER['REQUEST_SCHEME'] | https |
$_SERVER['CONTEXT_PREFIX'] | no value |
$_SERVER['CONTEXT_DOCUMENT_ROOT'] | /var/www/webroot/ROOT |
$_SERVER['SERVER_ADMIN'] | admin@etpsolutions.com |
$_SERVER['SCRIPT_FILENAME'] | /var/www/webroot/ROOT/index.php |
$_SERVER['REMOTE_PORT'] | 12133 |
$_SERVER['REDIRECT_URL'] | /forums/topic/33189-aiuto-clonare-ecu-13-m-jet/ |
$_SERVER['REDIRECT_QUERY_STRING'] | comment=237668&do=findComment |
$_SERVER['GATEWAY_INTERFACE'] | CGI/1.1 |
$_SERVER['SERVER_PROTOCOL'] | HTTP/1.1 |
$_SERVER['REQUEST_METHOD'] | GET |
$_SERVER['QUERY_STRING'] | comment=237668&do=findComment |
$_SERVER['REQUEST_URI'] | /forums/topic/33189-aiuto-clonare-ecu-13-m-jet/?comment=237668&do=findComment |
$_SERVER['SCRIPT_NAME'] | /index.php |
$_SERVER['PHP_SELF'] | /index.php |
$_SERVER['REQUEST_TIME_FLOAT'] | 1732312046.7453 |
$_SERVER['REQUEST_TIME'] | 1732312046 |
$_SERVER['argv'] | Array ( [0] => comment=237668&do=findComment ) |
$_SERVER['argc'] | 1 |
PHP Group |
Thies C. Arntzen, Stig Bakken, Shane Caraveo, Andi Gutmans, Rasmus Lerdorf, Sam Ruby, Sascha Schumann, Zeev Suraski, Jim Winstead, Andrei Zmievski |
Language Design & Concept |
Andi Gutmans, Rasmus Lerdorf, Zeev Suraski, Marcus Boerger |
PHP Authors | |
Contribution | Authors |
Zend Scripting Language Engine | Andi Gutmans, Zeev Suraski, Stanislav Malyshev, Marcus Boerger, Dmitry Stogov, Xinchen Hui, Nikita Popov |
Extension Module API | Andi Gutmans, Zeev Suraski, Andrei Zmievski |
UNIX Build and Modularization | Stig Bakken, Sascha Schumann, Jani Taskinen, Peter Kokot |
Windows Support | Shane Caraveo, Zeev Suraski, Wez Furlong, Pierre-Alain Joye, Anatol Belski, Kalle Sommer Nielsen |
Server API (SAPI) Abstraction Layer | Andi Gutmans, Shane Caraveo, Zeev Suraski |
Streams Abstraction Layer | Wez Furlong, Sara Golemon |
PHP Data Objects Layer | Wez Furlong, Marcus Boerger, Sterling Hughes, George Schlossnagle, Ilia Alshanetsky |
Output Handler | Zeev Suraski, Thies C. Arntzen, Marcus Boerger, Michael Wallner |
Consistent 64 bit support | Anthony Ferrara, Anatol Belski |
SAPI Modules | |
Apache 2.0 Handler | Ian Holsman, Justin Erenkrantz (based on Apache 2.0 Filter code) |
CGI / FastCGI | Rasmus Lerdorf, Stig Bakken, Shane Caraveo, Dmitry Stogov |
CLI | Edin Kadribasic, Marcus Boerger, Johannes Schlueter, Moriyoshi Koizumi, Xinchen Hui |
Embed | Edin Kadribasic |
FastCGI Process Manager | Andrei Nigmatulin, dreamcat4, Antony Dovgal, Jerome Loyet |
litespeed | George Wang |
phpdbg | Felipe Pena, Joe Watkins, Bob Weinand |
Module Authors | |
Module | Authors |
BC Math | Andi Gutmans |
Bzip2 | Sterling Hughes |
Calendar | Shane Caraveo, Colin Viebrock, Hartmut Holzgraefe, Wez Furlong |
COM and .Net | Wez Furlong |
ctype | Hartmut Holzgraefe |
cURL | Sterling Hughes |
Date/Time Support | Derick Rethans |
DB-LIB (MS SQL, Sybase) | Wez Furlong, Frank M. Kromann, Adam Baratz |
DBA | Sascha Schumann, Marcus Boerger |
DOM | Christian Stocker, Rob Richards, Marcus Boerger |
enchant | Pierre-Alain Joye, Ilia Alshanetsky |
EXIF | Rasmus Lerdorf, Marcus Boerger |
FFI | Dmitry Stogov |
fileinfo | Ilia Alshanetsky, Pierre Alain Joye, Scott MacVicar, Derick Rethans, Anatol Belski |
Firebird driver for PDO | Ard Biesheuvel |
FTP | Stefan Esser, Andrew Skalski |
GD imaging | Rasmus Lerdorf, Stig Bakken, Jim Winstead, Jouni Ahto, Ilia Alshanetsky, Pierre-Alain Joye, Marcus Boerger, Mark Randall |
GetText | Alex Plotnick |
GNU GMP support | Stanislav Malyshev |
Iconv | Rui Hirokawa, Stig Bakken, Moriyoshi Koizumi |
IMAP | Rex Logan, Mark Musone, Brian Wang, Kaj-Michael Lang, Antoni Pamies Olive, Rasmus Lerdorf, Andrew Skalski, Chuck Hagenbuch, Daniel R Kalowsky |
Input Filter | Rasmus Lerdorf, Derick Rethans, Pierre-Alain Joye, Ilia Alshanetsky |
Internationalization | Ed Batutis, Vladimir Iordanov, Dmitry Lakhtyuk, Stanislav Malyshev, Vadim Savchuk, Kirti Velankar |
JSON | Jakub Zelenka, Omar Kilani, Scott MacVicar |
LDAP | Amitay Isaacs, Eric Warnke, Rasmus Lerdorf, Gerrit Thomson, Stig Venaas |
LIBXML | Christian Stocker, Rob Richards, Marcus Boerger, Wez Furlong, Shane Caraveo |
Multibyte String Functions | Tsukada Takuya, Rui Hirokawa |
MySQL driver for PDO | George Schlossnagle, Wez Furlong, Ilia Alshanetsky, Johannes Schlueter |
MySQLi | Zak Greant, Georg Richter, Andrey Hristov, Ulf Wendel |
MySQLnd | Andrey Hristov, Ulf Wendel, Georg Richter, Johannes Schlüter |
OCI8 | Stig Bakken, Thies C. Arntzen, Andy Sautins, David Benson, Maxim Maletsky, Harald Radi, Antony Dovgal, Andi Gutmans, Wez Furlong, Christopher Jones, Oracle Corporation |
ODBC driver for PDO | Wez Furlong |
ODBC | Stig Bakken, Andreas Karajannis, Frank M. Kromann, Daniel R. Kalowsky |
Opcache | Andi Gutmans, Zeev Suraski, Stanislav Malyshev, Dmitry Stogov, Xinchen Hui |
OpenSSL | Stig Venaas, Wez Furlong, Sascha Kettler, Scott MacVicar, Eliot Lear |
Oracle (OCI) driver for PDO | Wez Furlong |
pcntl | Jason Greene, Arnaud Le Blanc |
Perl Compatible Regexps | Andrei Zmievski |
PHP Archive | Gregory Beaver, Marcus Boerger |
PHP Data Objects | Wez Furlong, Marcus Boerger, Sterling Hughes, George Schlossnagle, Ilia Alshanetsky |
PHP hash | Sara Golemon, Rasmus Lerdorf, Stefan Esser, Michael Wallner, Scott MacVicar |
Posix | Kristian Koehntopp |
PostgreSQL driver for PDO | Edin Kadribasic, Ilia Alshanetsky |
PostgreSQL | Jouni Ahto, Zeev Suraski, Yasuo Ohgaki, Chris Kings-Lynne |
Pspell | Vlad Krupin |
Readline | Thies C. Arntzen |
Reflection | Marcus Boerger, Timm Friebe, George Schlossnagle, Andrei Zmievski, Johannes Schlueter |
Sessions | Sascha Schumann, Andrei Zmievski |
Shared Memory Operations | Slava Poliakov, Ilia Alshanetsky |
SimpleXML | Sterling Hughes, Marcus Boerger, Rob Richards |
SNMP | Rasmus Lerdorf, Harrie Hazewinkel, Mike Jackson, Steven Lawrance, Johann Hanne, Boris Lytochkin |
SOAP | Brad Lafountain, Shane Caraveo, Dmitry Stogov |
Sockets | Chris Vandomelen, Sterling Hughes, Daniel Beulshausen, Jason Greene |
Sodium | Frank Denis |
SPL | Marcus Boerger, Etienne Kneuss |
SQLite 3.x driver for PDO | Wez Furlong |
SQLite3 | Scott MacVicar, Ilia Alshanetsky, Brad Dewar |
System V Message based IPC | Wez Furlong |
System V Semaphores | Tom May |
System V Shared Memory | Christian Cartus |
tidy | John Coggeshall, Ilia Alshanetsky |
tokenizer | Andrei Zmievski, Johannes Schlueter |
XML | Stig Bakken, Thies C. Arntzen, Sterling Hughes |
XMLReader | Rob Richards |
XMLWriter | Rob Richards, Pierre-Alain Joye |
XSL | Christian Stocker, Rob Richards |
Zip | Pierre-Alain Joye, Remi Collet |
Zlib | Rasmus Lerdorf, Stefan Roehrich, Zeev Suraski, Jade Nicoletti, Michael Wallner |
PHP Documentation | |
Authors | Mehdi Achour, Friedhelm Betz, Antony Dovgal, Nuno Lopes, Hannes Magnusson, Philip Olson, Georg Richter, Damien Seguy, Jakub Vrana, Adam Harvey |
Editor | Peter Cowburn |
User Note Maintainers | Daniel P. Brown, Thiago Henrique Pojda |
Other Contributors | Previously active authors, editors and other contributors are listed in the manual. |
PHP Quality Assurance Team |
Ilia Alshanetsky, Joerg Behrens, Antony Dovgal, Stefan Esser, Moriyoshi Koizumi, Magnus Maatta, Sebastian Nohn, Derick Rethans, Melvyn Sopacua, Pierre-Alain Joye, Dmitry Stogov, Felipe Pena, David Soria Parra, Stanislav Malyshev, Julien Pauli, Stephen Zarkos, Anatol Belski, Remi Collet, Ferenc Kovacs |
Websites and Infrastructure team | |
PHP Websites Team | Rasmus Lerdorf, Hannes Magnusson, Philip Olson, Lukas Kahwe Smith, Pierre-Alain Joye, Kalle Sommer Nielsen, Peter Cowburn, Adam Harvey, Ferenc Kovacs, Levi Morrison |
Event Maintainers | Damien Seguy, Daniel P. Brown |
Network Infrastructure | Daniel P. Brown |
Windows Infrastructure | Alex Schoenmaker |
This program is free software; you can redistribute it and/or modify it under the terms of the PHP License as published by the PHP Group and included in the distribution in the file: LICENSE This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. If you did not receive a copy of the PHP license, or have any questions about PHP licensing, please contact license@php.net. |
