In basso potete vedere le funzioni attivate. Costo del nuovo oltre 10000€. Vendo a 5000€.
VAG
AN002-Cluster CAN
AN003-Cluster PIN-CAN
AN004-Immo Panel
AN006-Cluster K-Line
AN008-Flasch Counters
AN011-TV Configuration
AN021A-EDC16 Calibration
AN015-Flsch Memory ECU
AN021-ME7 Conf Data
AN028-Cluster CAN UDS
AN032-Security code by CAN
AN033-ECU Conf Data (EDC15,ME7.x.x
AN034-Cluster-PIN Calibration-K-Line
AN044-Instrument Cluster Engine Control Module Recalibration
BMW
BN002-Memory manager
BN003-CAS1 CAS2 read update
BN004-CAS3 read update
BN006-CAS3 keys by OBD
BN007- EBridge Tool
FIAT
FN007-Transponder Maker
FN013 - Instrument cluster data manager for Fiat/Lancia/Alfa Romeo
FN015 - Engine control unit configuration manager
FORD
FR005-Instument Cluster Module Recalibration
MERCEDES
MN002-Cluster Calibration by OBD (K-Line), Assist Plus
MN007-CGW (Central Gateway)Read Update ConfData
MN010-Cluster Calibration for S-Class W221,CL W216 and Sprinter,Vito,Viano (after2006)
MN011-Can Dash Cluster Calibration- W211,W219,W164,W251,203
MN015-Cluster Calibration Mercedes
OPEL
ON004-Cluster Calibration
ON004 Radio
ON004-Airbag
ON007-Tech2Win Driver
ON009-Calibration-IPC,ECU;Airbag_Clear Crash,Read Radio Code
PSA
PN002-EDC15-Read Update Configuration Data, Calibration
PN004-BSI Calibration
PM005-Cluster and BSI Calibration
PN007-Cluster and BSI Calibration, Read Update Configuration Data
PN011-BSI,Instrument Cluster Data Manager
RENAULT
RR004-Laguna 3 Cluster Calibration
TagKey Tool
KT001-Tag KEY Tool programmer 55105509
KT005-VAG TP22,TP23,TP24.Tp25 production
KT010-TAG KEY TOOL
Modificato da aerosmith
  • 5 mesi dopo...
Il 10/3/2017 at 21:47 , aerosmith ha scritto:
Up, nuovo prezzo 4000€
ciao sono interessato,se mi contatti ne possiamo parlare...
@aerosmith e @jtd potete anche postare eventuali email unicamente per contattarvi ma DOVETE notificare la chiusura o canellazione del post o dei dati personali a fine transazione.. basta anche fare la "segnalazione" cliccando qui
Almeno si svicola il limite dei PM abilitati post 100msg e potete contattarvi.. questo è stato deciso solamente nei post di vendita.. non fate post con contatti email altrimenti vi stacco le braccine! ;)
Grazie e buon forum
Ancora disponibile, l'utente non sapeva nemmeno di che prodotto stavamo parlando, quindi pregherei i prossimi interessati ad informarsi prima. Grazie per l'attenzione
  • 3 mesi dopo...
UP, ancora disponibile!
Per cortesia mi contattassero solo utenti che già sanno di cosa stiamo parlando. Per gli altri c'è la mail abrites a cui chiedere informazioni!!!
