4 ore fa, Laurynas ha scritto:
Ciao,
forse qualcuno ha mappack per questo?
1037372790 W203 2.7
o simili edc16c3 vecchio file? Grazie
letto con mpps.
dispiace per che io parlo solo in inglese
1037372790_w203.Bin
Google translate save all ! :D
Please read the policy roule and make your presentation on the dedicated post.
Tnx
Tnx
Where is policy rules of presentation? :) sorry for misunderstanding
In questo momento, Laurynas ha scritto:
Thank you for guide ! I have done my presentation ;) And now analyzing rules of forum..
Sorry again. It's very hard to orientate.
dont worry, be happy!
Address Name Size
$00000 Hexdump
$191ACE DW 1 8x8
$19188A DW2 8x8
$192356 DRAG TORQ ? 16x14
$194646 EGR 16x12
$1A8A62 Smoke map by MAP ? 16x16
$1E2CA6 Turbo 1 12x16
$1E37FA Turbo 2 12x16
$1E2A62 Turbo 4 12x16
$1F04F2 Rail Pressure 1  15x16
$1F0826 Rail Pressure 2 16x16
$1E2E26 Turbo 1 limiter??? 7x10
 what i found..
3 ore fa, Tky ha scritto:
Give more info..
vehicle type ?
What type? Mercedes Benz C - klass C270 EDC16CP3 2005 yrs. model.
I need torque limiters... :( DOI, EGR hysteris, Smoke or lambda maps, Rail limiter
giving a quick glance I can tell you that one of the torque limiters you find the IND. 1a81d4 to 1a822c and is set to deliver a minimum of 38 to a maximum of 70 then dropping obviously, to increase it to your desires you should control the amount of air that the engine is able to store as under torque they are easy to smoke , bye, see you soon.
  • Like 3
