Il 17/11/2016 at 20:48 , gugly12 ha scritto:
Qualcuno ha esperienza con questo strumento ??
Qualcuno ha una guida per capire meglio le funzioni speciali
1. By OBDII - Comprehensive Mileage Recalibration for W221 and W216 vehicles. The mileage is changed in the following units: CGW, EZS, Instrument Cluster and
all other units, which store the mileage (like Tire Pressure Monitor and Adaptive Brake, for example) , Read/Write service history records in ZGW of W221 S-Class
and W216 CL, Read/Write complete EEPROM and Flash of CGW (Central gateway) of W221 S-Class and W216 CL, Mileage Recalibration in dashboard for Vito, Viano, Sprinter
after 2006 year
E-Class W211, CLS W219, GL X164, ML W164, R-Class W251, CLK W209, C-Class W203 and G-Class W463
A-Class W169, B-Class W245
2. By OBDII - Mileage Recalibration for W204/W212/X204/W197/W207 vehicles. The mileage is changed in the following units: ASSYST, ASSYST Plus, EZS, Instrument Cluster
3. By OBDII - Read/Write EEPROM of Dashboard control units, ESP, Sensotronic Brake Control (SBC) and many others...
Online manual for Sensotronic Brake Control Repair
4. By OBDII - Airbag - Read/Write EEPROM, Clear Crash Data, Erase Motohours
5. Dump Tool - calculate mileage values, reset mileage values, clear airbag crash data, make engine control virgin and so on
6. By OBDII - ECU - Read/Write Flash, Read/Write EEPROM of Engine Control Units
7. DAS-2 - Generation of key dumps for vehicles with DAS-2 Immobilizer system.
8. DAS-2a - Programming transponder keys for DAS 2a Immobilizer system (W168 A-Class).
9. By OBDII - DAS-2b - Key Learning for Mercedes W163; Read/Write EEPROM of AAM/EAM control modules; Learn radio code of transmitter keys; Deactivate/Reactivate keys
10. Transponder generation
11. By OBDII - TV/AUX activation/deactivation
12. By OBDII - Seatbelt warning activation/deactivation
13. By OBDII - Reverse warning activation/deactivation
14. By OBDII - Activation/deactivation of Speed warning for Gulf States
15. Electrical Steering Lock (ESL) - Read/Write/Unlock EEPROM of ESL for the following vehicles: W202, W208, W209, W210, W203, W211, W219 by direct connection to
the ESL module.
Please, note that in order to erase or write the EEPROM of this type of ESL you need to have the ESL database.
16. Electrical Ignition Switch (EIS, K-Line) - Read EEPROM of EIS and ESL modules by diagnostic connection to the EIS module; Open/Close ESL
17. Electrical Steering Lock (ESL, CAN) - Disable/Enable keys; Write VIN of new units; Activate/Deactivate ESL; Activate/Deactivate EZS
18. Generation of Dumps for programming keys for cars, which use DAS-3 system. With the IR Key Manager special function you can generate keys for the following
vehicles: W203, W208, W209, W210, W211, W215, W219, W220, W230, W639. The generated dumps should be programmed in the EZS, ESL and the key. For the key all NEC
processors and the following Motorola processor is supported: MA 567 880 051, 654 367 2004
For all owners of MN005 license - If you have a Motorola key (it doesn't matter if it is working key or not, as long as it is from the same car) we can send you
working key dumps without the need to disassemble, remove and read the EZS! Just read the EZS by diagnostics from the Special Function "EIS K-Line" and send
the dump together with the dump from the Motorola key to [email protected] . We will send you working key dumps FREE of charge within 1 working day.
ZN002 - NEC programmer - for NEC MCU's assembled in the IR-Keys
19. By OBDII - Change ASSYST PLUS Service maintenance records
20. By OBDII - Change ASSYST Service maintenance records
21. By OBDII - Read/Write COMPLETELY EEPROM of Central Gateway (CGW) via OBDII. Works for the following vehicles : W211, W171, W219, W164, X164, W169, W245, W204, W212, X204, W218
22. Custom requests
23. By OBDII - SMART key teach-in (K-Line and CAN)
24. By OBDII - Renew of 7-Gear Electronic Transmission Control Unit (722.9) and ISM - Intelligent Selector Module
Screenshot:
fvdi abrites benz commander
Trovi molto altro cercando su google... buona ricerca ;)
