Automan Inviato 30 Novembre 2017 Condividi Inviato 30 Novembre 2017 Buongiorno ragazzi, volevo sapere se era possibile leggere e scrivere la centralina della Fiat panda 1.3 mj del 2004 (quella senza fap) con Mpps v.12 e se era possibile rimuovere l'egr con il software Egr Remover. Link al commento Condividi su altri siti Altre opzioni di condivisione...
Automan Inviato 30 Novembre 2017 Autore Condividi Inviato 30 Novembre 2017 Queste sono le centraline auto che mi elenca il programma -------------------------------------------------------------- (Isuzu models supported to : NRP300,NRP500, Canter,NR400, NNR200, EFI, Dmax, Truck) - Adblue VAG EDC17CP24 has been improved - Adblue - DAF PC3 has been improved for new models. - Adblue EDC17CP20 improved for Passat models. - Adblue EDC17CP20 more improved - Alfa EDC16C39 Solution 2 improved for some file types. - Audi - VW EDC17CP04 improved for new models. - Audi - VW EDC16U31 4x switch type file signs added - Audi - VW EDC16U31 Switch solution added - Audi - VW EDC16U34 P0545 and P0546 DTC automatic removing added - Audi - VW EDC17C46 signs more improved - Audi - VW EDC17C46 signs more improved - Audi - VW EDC17CP04 Flap removing added - Audi - VW EDC17CP04 solution has been improved - Audi - VW EDC17CP20 Flap solution has been added - Audi EDC16CP34-4 revized fixed. - Audi EDC16CP34-4 solution revised with new. - Audi EDC17CP04 2th switch added - Audi EDC17CP14 has improved for support to Q5 models. - Audi EDC17CP44 switch fixed for Audi car. - Audi EDC17CP54 added - Audi PCR2.1 regeneration switch alternate added - Audi PPD1.x new solution added - BMW 1mb Type1 solution added 525 models. - BMW EDC16C35 supported to all types (Generic) - BMW EDC16C35-2 item added DDE7 support - BMW EDC17C41 added - BMW EDC17C56 solution added - BMW EDC17CP06 DTC Root + DTCx80 removing added - BMW EDC17CP45 ASC solution added - BMW Mini EDC15C35 bug fixed. - Chevrolet DCM3.7 improved, DTC structure fixed - Chevrolet Delphi DCM3.7 acceleration problem fixed - Chevrolet EDC16C39 added - Chevrolet EDC16C39 has been improved - Chevrolet EDC16C39 improved - Chrysler EDC16C31 added alternate solution - Chrysler EDC16CP31 solution improved - Citroen - Peugeot EDC17C10 added more DTCs - Citroen - Peugeot EDC17C10 Additive Pump removing improved - Citroen Berlingo EDC17C10 added - Citroen Delphi DCM3.5 Type2 added in main solution - Citroen EDC17C10 solution Picasso model support added - Citroen SID803A supported with Peugeot SID803A solution now - Citroen SID807 EGR + DPF added - Citroen SID807 sign are improved - Dacia Delphi DCM3.4 solution has been added - Dacia Delphi DCM3.4 solution has been added. - Dacia section added with EDC17CP42 ECU. - Denso map8 problem fixed - Dodge EDC16U31 solution has been added - EDC17CP02 - CP06 New DTC's added - EDC17CP14 Flap removing has been improved for different models. - EDC17CP14 solution improved - EDC17CP24 bug fixed Tamarrov - Fiat 6F3 Generic added Fiat500 models - Fiat 8F2 signs are improved, - Fiat 8F3 solution fixed - Fiat 8F3 solution Improved - Fiat 8F3 solution Improved - Fiat Doblo 6Fx improved for other models - Fiat Ducato type more improved - Fiat EDC16C39 Generic improved for Chrome models. - Fiat Grande Punto 8F2 improved to other models - Fiat Marelli 6F3 solution automatic EGR disable function removed. - Fiat Marelli 8F3 Generic P1564 DTC removing has been added - Fiat Marelli 8F3 solution added - File control : CMD, Kess formats and blank file controlling added. - Fixed 62 signs problems reported by customers. - Fixed some Flap items was showing DPF removing message. - Flap EDC16C34 EDC16CP34 revised - Flap EDC16U1 Golf5 new sign added - Flap EDC17CP14 Audi different type sign added - Flap EDC17CP14 Audi different type sign added - Ford 9M51 type solution item added - Ford DCM3.5 Type2 solution(983kb) has been improved for Mondeo models - Ford Connect Solution new DTCs added for removing - Ford Delphi DCM3.2 solution has been added. - Ford Delphi DCM3.5 Improved for other models. - Ford Delphi DCM35 P2463 and P246b DTC removing added - Ford EDC16C3.9.18 added - Ford EDC16C34 Additive removing added - Ford EDC16C34 improved for Cmax models - Ford EDC16C34 switch P2484 2th DTC added - Ford EDC17C10 solution has been added - Ford Focus EDC16C34 Switch solution new signs added - Ford Mondeo Delphi DCM3.5 type ECU solution added - Ford Sid206 Generic improved for Mondeo model - Ford SID206 Generic solution improved for modified files. - Ford SID206 Kuga renew solution tested with - Ford SID208 EGR + DPF added - Ford SID208 P244D DTC removing added - Ford SID208 Transit and Ranger models supports improved - Ford SID803A new solution added - Ford Transit Connect Type solution added new DTCs - Ford Transit Connect Type solution added new DTCs - Ford, Citroen, Peugeot, Volvo EDC16C34 switch solustion - Generic EDC16 - EDC17 Switch search improved with new add switch solutions - Golf5 EDC16U1 Flap added - Honda Civic solution improved for different ECU soft versions. - Honda EDC16C31 solution improved - Honda EDC17CP06 has been improved - Honda EDC17CP16 switch solution added - Honda EDC17CP16 switch solution added - Hyundai - KIA EDC16C39 Switch solution added - Hyundai / KIA EDC17C08 Double DPF switch problem fixed - Hyundai EDC16C39 Generic improved for Tucson models. - Hyundai Generic Switch solution new DTC's added - Hyundai SantaFe solution added - In Toyota Denso solution added Prado VX model support. - Isuzu Transtoron NR400 Model EGR + DPF support added - Isuzu Transtron Dmax added - Isuzu Transtron EFI, Canter, NLP models solution added - Isuzu Transtron improved for Dmax Type2 models. - Isuzu Transtron NNR200 model support added - Isuzu Transtron P2002 P0401 automatic DTC removing has been added - Italian language text has been revised - Italian Language totally revised, now more good - Iveco EDC17CP52 more DTCs removing has been added - Iveco EDC17CP52 solution added (EGR + DPF) - Jaguar EDC17CP11 added - Jaguar EDC17CP11 fixed some DTC's - Jaguar SID204 fixed, improved for added models. - Jaguar SID204 reported P0000 problem fixed - Jaguar SID204 solution has been improved - Jeep and Dodge EDC17C79 switch solution has been added - Jeep EDC16CP31 DTC removing improved. - Jeep EDC16U1 added new automatic switch solution - Jeep EDC16U1 added new automatic switch solution - Jeep EDC17C79 added - Jeep Grand Cheroke EDC16CP31 added - KIA Carens 5th search point fixed - KIA EDC17C08 solution has been improved. - KIA EDC17C08 Switch added - Lancia 6f3 Solution added - Lancia 8F3 solution improved - Lancia EDC16C39 added - LandRover Sid208 added - M55 solution improved for 1mb files. - Mazda 3 Denso models P2584 P2585 DTC removing added - Mazda CX7 Adblue + DPF more improved - Mazda CX7 Adblue remove added - Mazda Denso Partial DTC added - Mazda EDC16C34 revised. - Mazda EDC16C34 Switch solution added - MB EDC16C31 2011+ solusyon improved for MB Vivano models. - MB EDC17C10 Switch added, DTC's improved - MB Flap M55 improved. - Mercedes EDC17C01 - CP01 switch solution has been added - Mercedes 2011+ solution restored again. - Mercedes DCM3.5 4MB Type2 solution added - Mercedes DCM3.5 solution DTC P244A added - Mercedes DCM3.5 Type1 solution improved, added new DTC's. - Mercedes DCM3.5 Type2 DTC section totally revized - Mercedes DCM35 CRD Type2 4MB P2454 DTC removing added - Mercedes Delphi DCM3.5 CRD2 Type1 solution added P2279 automatic removing - Mercedes Delphi DCM35 Type1 P0475 automatic removing added - Mercedes EDC16C31 - CP31 item improved for MB CLS Models - Mercedes EDC16C31 1mb Type1 solution improved for W211 models - Mercedes EDC16C31 Type2 Generic solution improved - Mercedes EDC16CP31 solution improved for ML models - Mercedes EDC16CP31 solution improved for ML models - Mercedes EDC16CP36 solution revized - Mercedes EDC16CP36 Type1 solution 2 new signs added - Mercedes EDC17CP10 solution improved. - Mercedes EDC17CP10 solution revized - Mercedes EDC17CP46 solution improved - Mercedes ML EDC16C31 support has been improved - Mercedes Sprinter EDC17CP46 switch solution added - Mercedes Sprinter EDC17CP46 switch solution added - Mitsubishi Denso 2th solution added for compatible other some models. - Mitsubishi Denso has been improved - Mitsubishi EDC16CP39 Switch solution has been added - Mitsubishi EDC17CP15 DPF + EGR solution has been added - Mitsubishi EDC17CP15 has been improved - Nissan EDC16CP33 Type2 solution has been improved for more new models. - Nissan EDC17C42 opening problem has been fixed - Nissan SID305 P1525 fixed, improved - Opel - Vauxhall OpelEDC17C59 Switch solution added - Opel EDC17C59 improved. - Opel Astra J special solution added - Opel Astra J special solution added - Opel Denso Partial DTC solution improved - Opel Denso solution improved for DTC, light problems - Opel EDC16C39 Antara added in main solution. - Opel EDC16C9 EGR + DPF 1x P1901 DTC fixed. - Opel EDC16C9 EGR + DPF 1x P1901 DTC fixed. - Opel EDC17C18 - 19 revized - Opel EDC17C18 Corsa D files signs has been added. - Opel EDC17C18 improved - Opel EDC17C18 some DTC problems fixed - Opel EDC17C18-19 solution improved - Opel EDC17C18-19 solution improved for Vauxhall EDC17 ECUs - Opel EDC17C42 added from Nissan and Reanult solutions - Opel Marelli 75-90CV solution added new file type sign - Opel Z13DTJ improved - PCR2.1 solution added new DTCs - PCR2.1 solution added new DTCs - PCR2.1 solution improved for Golf 1.6TDI models. - Peugeot EDC16C34 solution improved for some models. - Peugeot DCM3.4 added in Citroen section - Peugeot DCM3.4 solution improved. - Peugeot DCM3.5 solution improved for other models. - Peugeot EDC15C2 different type signs added - Peugeot EDC15C2 some DTCs removing added - Peugeot EDC16C34 P2033 and P1461 DTC removing added - Peugeot EDC17C10 disable more DTC's about DPF additive system - Peugeot SID803 MPC solution has been improved. - Peugeot SID803A Generic improved. - Peugeot SID803A Generic item improved for Peugeot Expert2.0 models - Peugeot SID803A Generic solution improved - Peugeot SID803A Type new signs added - Peugout DCM3.4 improved for more compatible - Peugout SID803A generic added Boxer model signs - Peugout SID803A generic added Boxer model signs - PPDv1.x revized with new solution. - Protections improved, lots of trap points added. - PSA Delphi DCM3.5 added - PSA EDC15C2 bug fixed - PSA EDC16C0-7, EDC167C0-9 improved - PSA EDC17C09 - 10 bug fixed - PSA Group EDC15C2 Aditiv + Flap removing added - PSA SID803 MPC more improved - PSA SID807 item normal and EVO integration has been completed. - Range Rover EDC17CP11 added, improved. - Renault (Laguna) EDC16C3 solution revized - Renault and Nissan EDC17C42 solution added - Renault and Nissan EDC17C42 solution added - Renault DCM3.4 New DTCs automatic removing has been added - Renault Delphi DCM3.4 solution improved with new DTCs - Renault Delphi DCM34 solution has been improved - Renault EDC16C3 Type1 and Type2 DTC's optimized - Renault EDC16CP33 sign are improved. - Renault EDC16CP36 improved - Renault EDC17C11 Switch added, improved - Renault EDC17C42 improved - Renault EDC17C42 new automatic DTCs added. - Renault EDC17C42 P0294 DTC automatic removing added - Renault EDC17C42, Saab EDC16C39 solution signs are improved. - Renault SID305 new sign added - Renault SID305 P1525 and P2002 extra DTC removing codes added - Renault SID305 solution added - Renault SID305 solution improved for Laguna models. - Renault Type2 improved - Saab EDC16C39 bug fixed - Seat EDC17U01 Ibiza model ECU extra DTCs added - SID206 Generic added Galaxy model points - SID305 Nissan and Megane added - SID803 MPC DTC0000 problem has been fixed. - Siemens PPD1.x Flap removing has been added - Siemens PPD1x ECU's added New optimized solution - Skoda EDC17U01 switch solution added - Skoda SuperB EDC16U31 added - Subaru Denso added - Subaru Denso DTC calculation bug has been fixed - Suzuki DDIS optimized - Suzuki EDC16C39 solution improved - Suzuki EDC16C39 solution improved for other models. - Suzuki EDC16C8-10 solution has been improved. - Swedish Language has been added - Toyota Denso solution has been improved - Toyota Denso solution improved - Toyota EDC17CP07 improved for Yaris, Auris models - Toyoto Denso P2031 DTC added - Toyoto Denso P2031 DTC added - Treeview font 1 punto decreised. - Update EDC16-17 fast search section. - Vauxhall - Opel EDC17C59 solution improved - Volvo SID803 MPC DTC removing has been optimized for DPF relate only - Volvo EDC16C31 Switch solution DTC area optimized - Volvo EDC16C31 solution DTC removing has been improved - Volvo EDC16C34 Additive Control and Liquid DPF automatic removing added - Volvo EDC17CP22 + EGR + DTCs added - Volvo SID803 MPC solution improved - Volvo SID803A Revized - VAG EDC17C64 solution improved for other models. - VAG DCM37 solution DTC bug has been fixed. - VW - Porsche EDC17CP44 added - VW Amarok EDC17CP52 switch solution aded - VW Audi Q7 EDC17CP24 Switch added and improved for other models - VW Crafter added new signs for supporting to different soft versions. - VW EDC16C46 Passat Models P246e DTC automatic added - VW EDC17C64 switch solution has been added - VW EDC17CP14 solution improved for Golf6 models - VW EDC17CP14 Swirl Flap solution added - VW EDC17CP24 DPF Switch sign revized - VW EDC17CP46 DTC Root + DTCx80 removing added - VW EDC17CP52 menu bug fixed - VW EDC17CP54 Switch solution added - VW Group EDC17C46 new DTCs added Alfa : EDC16C39 Type1 and Type2 Audi : EDC16UX,EDC16CP3 / 34, EDC16U31, EDC17CP14, Siemens PPD v1.1, V1.2, V1.3, EDC17CP44,EDC17C46,EDC17CP04, EDC16C34-4 BMW : EDC16C31 - 35, EDC16C31 (1MB), EDC17CP02,EDC16CP35, EDC16C31New, EDC16C35,EDC17CP45 EDC17C41 Chrysler : EDC16CP31 Chevrolet : EDC16C39 Citroen : EDC15C2, EDC16C34, EDC17C10, SID807 Fiat : EDC16C39(Ducato), EDC16C39 JTD, MJD 6F3, 6F3 Doblo, EDC16C39 Generic, SID803A, Marelli 8F2, Marelli 8F3, Ford : EDC16C34,EDC16C34-2, EDC16C34-2.29, EDC16C34-5, SID 206, SID807, SID803MPC, SID803A, SID206(SMAX type), SID206 Kuga, EDC16C34 Picasso Type, EDC16C3-9.18 Lancia : EDC16C39 Honda : EDC16C31, EDC17CP06, EDC16C31(Advanced) Hyundai / KIA : EDC16C39-D373, KIA EDC16C39 Type2, Hyundai EDC16C39 Caren, EDC16C39 SantaFE, EDC17C08 Iveco : EDC16C39 Isuzu : Denso, Transtron DMax Jaguar : SID204, EDC17CP11 Jeep : EDC16U1, EDC16CP31, EDC17C49 LandRover : EDC16C39-Ford, SID208 Mazda : Denso 3-8 all series, EDC16C3,Denso CX7 Type with Adblue, EDC16C34 Mercedes : EDC16C31, Delphi DCM3.4, EDC16C31 Vito and Type2, EDC16CP36, EDC16C3, EDC16C31(2011+) EDC17CP10,M55 Error fixer Mini Cooper : EDC16C35 Mitsubishi : Denso (Full 2 types supported), EDC16CP39 Nissan : Denso,EDC16C36, EDC16CP33 Type1 and Type2, SID305 Opel-Vauxhall : Denso,Denso Signum,EDC16C39, EDC16C9, EDC17C18 - C19, Marelli MJET 75-90cv, Z16DT Marelli, Denso Signum, Z16DTC, Z19DT Peugeout : EDC16C34, EDC15C2, SID803 MPC,Delphi DCM3.5, SID803A, Delphi DCM3.4 Porsche : EDC17CP44 Range Rover : EDC17CP11 Renault : EDC16C3 Type1 and Type2,EDC16C32, SID305,EDC16C11 Saab : EDC16C39,EDC16C9 Skoda : EDC17CP14, PCR2.1, Octavia19 Bosch,EDC17U01,EDC17CP20,EDC16CP44,EDC17U01 Seat : Siemens PPD V1.2, PCR 2.1,, EDC17U01,EDC17CP20,EDC16CP44 Subaru : Denso Suzuki : EDC16C3 Type1 and Type2, EDC16C39 Toyota : EDC17CP07 Volvo : EDC16C31 Type1 and Type2,SID803MPC,EDC16C34, SID803A Type1 and Type2, EDC17CP22 VW : EDC16CP34, EDC16U31,,EDC17CP14, PCR2.1, EDC16CP34-4, EDC17U01,EDC17CP20,EDC16CP44 EDC17CP46,EDC17CP52,EDC17P24, EDC17CP44, EDC17CP54 All : EDC16 - EDC17 ECU's automatic DPF switch finder item * : Some EDC16 and all EDC17 ECU's solutions are using internal switches. --------------------------------------- Flap support list: -------------------------------------- Audi a4, a6 EDC16CP34 Toureg EDC16CP34-4 Jeep EDC16CP31 Audi EDC16C34 Alternate Audi V6TDI 3.0 Vectra C EDC EDC15VM P0098 (In EGR Remover) EDC16U1 Flap Solution EDC17CP04 EDC17CP14 ------------------------------------------------------------ Professional EGR Remover v2017.05.1 ------------------------------------------------------------ - Added these custom DTC removers : - Citroen - Peugeot EDC17C10 - Audi VW MED17.1 - Mercedes EDC17CP46 - Toyota EDC17CP07 - CP37 - Hyundai - KIA EDC16C39 - BMW EDC17CP45 - Mitsubishi EDC17CP15 - BMW EDC17CP35 - Fiat Marelli 8F3 - BMW EDC18CP09 - VAG EDC16C34 - Fiat EDC16C39 - Ford EDC17C10 - Iveco EDC17CP52 - Toyota EDC16C31 - EDC17CP04 - EDC17CP14 - EDC17CP20 - EDC17CP46 - EDC17C64 - MB EDC17CP10 - BMW EDC17CP02 - Alfa EDC16C8 - Honda EDC17CP06 - Renault Nissan SID305 - Peugeot - Citroen EDC16C34 -Fiat, Alfa ,Chevrolet EDC15C7 -PSA Group SID803a -Ford SID803 -Ford SID803a -Ford SID206 -PPDv1.x -Mercedes EDC16C31 -VW EDC16U1 series -EDC17CP14 custom DTC Removing internal BETA (next update will be added) -Still in progress : Delphi DCM3.5, DCM3.7 EGR, Opel Denso, (in development, tested) -Ford EDC16C34.2.30 total DTC -Alfa EDC16C39 total DTC -Audi EDC17C14 P2014 (Flap) -VM EDC15CVM P0098 (Flap) -Mercedes EDC16C31 DTC full table erase -Immo Generic EDC17 Solution. -------------------------------------------------------------- - 103 alternate signs added, increising file supporting - Alfa EDC16C39 Generic has been improved for other models. - Alfa EDC16C39 generic solution improved more - Alfa EDC16C39 generic solution improved more - Alfa EDC16C39 Solution1 added more sings for Alfa - Fiat - Lancai models - Alfa EDC16C8 has been more improved - Alfa EDC16C8 P0401 DTC automatic removing has been added - Alfa EDC17C49 EGR + DPF added - Alfa Guilette EDC16C39 special solution added in Type1 item - Audi - Skoda EDC15P solution added - Audi - VW EDC16U31 Generic revized, EDC16U34 ignored. - Audi - VW EDC17C46 solution improved with new DTCs - Audi - VW EDC17C46 Type4 solution added. - Audi - VW Marelli 4MV added Golf4 models supports. - Audi - VW ME7.5.10 solution improved and added on Audi cars support - Audi - VW PCR2.1 generic added new DTCs - Audi - VW PCR2.1 generic item support problems has been solved. - Audi A3 models EDC17C46 EGR hysteresis map problems has been fixed. - Audi EDC15VM+ solution now generic - Audi EDC16U31 Type1 solution revized - Audi EDC17CP14 Type2 solution added - BMW EDC15 Switch solution added - BMW EDC16C31 solution improved. - BMW EDC17C06 improved - BMW EDC16C31 custom DTC calculation bug fixed. - BMW EDC17C06 solution improved with new DTC removing - BMW EDC17CP02 added - BMW EDC17CP02 and EDC17C06 supported now, DTC's has been added - BMW EDC17CP02 EDC17CP06 solution problems are fixed. - BMW EDC17CP02 solution has been improved. - BMW EDC17CP06 improved - BMW EDC17CP06 revised. - BMW Mini EDC16 solution revized - Chrysler EDC15 EGR switch solution added - Chrysler EDC15 EGR switch solution added - Citroen - Peugeot EDC16CP39 added RuiSouza - Citroen - Peugeot SID803a Type2 new DTC's added. - Citroen - Peugout EDC16C34 EGR removing solution seperated - Citroen EDC15C3 3 new DTCs added. - Citroen EDC16C34 Berlingo signs added - Citroen EDC17C10 solution added - Citroen SID803A type custom DTC added in SID803 item - Custom DTC removing EDC17C46 Tiguan ECUs supports has been added. - EDC16U1 new type added, bug fixed. - EDC16U34 Generic Switch added, improved - EDC16U34 has been improved for other models. - EDC17 Immo section improved for other EDC17 ECU's - EDC17C46 - CP46 bug has been fixed. - EDC17C46 fixed for Passat and Alhambra models. - EDC17C46 Type overflow fixed. - EDC17CP04 solution improved - EDC17CP14 custom DTC removing improved for other models. - EDC17CP14 Solution1 P0401 DTC disabled added. - EDC17CP24 DPF signs conflict fixed - Fiat 8F3 improved for specially Ducato models - Fiat 8F3 solution P0409 and P0486 removing added - Fiat Bravo model added in Fiat Generic EDC16c39 item - Fiat Doblo solution improved - Fiat ducato type added - Fiat Marelli 8F2 and 8F3 EGR solution added - Fiat Marelli 8F3 solution added generic P0486, P0488,P0489 and P0409 DTC removing - Fiat SID803A added new DTCs for removing automatical - Fiat SID803A file id check has been removed, solution improved - Fiat,Alfa,Opel, Lancia, Citroen, Ducato,Hyundai,KIA,Saab EDC16C39 generic switch solution added - File control : CMD, Kess formats and blank file controlling added. - Flap EDC16C34 Generic improved for EDC16C34 softwares - Flap EDC16U31 P3103 added - Flap EDC16U34 solution2 DTC calculation added - Flap EDC17CP04 added - Flap EDC17CP14 some models bug fixed ( - Ford DCM3.5 improved for other models. - Ford Delphi DCM3.5 solution optimized, revised - Ford EDC16C34 Additive removing added - Ford EDC16C34 Focus models bug has been fixed - Ford EDC16C34 M.Patil Type ECU software solution has been added - Ford EDC16C34 signs are improved for different soft versions - Ford EDC16C34 some version support fixed - Ford EDC16C34 Switch solution added U0118 DTC disabled - Ford Sid 202 EGR Hyst. added - Ford SID202 P0489 DTC removing added - Ford SID204 added new DTC points - Ford SID206 Generic solution improved for other models. - Ford SID206 P0490 added - Ford SID206 P141a DTC conflict has been fixed. - Ford SID206 P246x DTCs added - Ford SID206 revized - Ford SID206 Type DTC's improved - Ford SID206 Type EGR Hystresis map problem solved. - Ford SID208 different size maps added - Ford SID208 has been improved - Ford SID208 improved - Ford SID208 more DTCs added - Ford SID208 optimized for Ranger and Transit model. - Ford Sid802 solusyon improved - Ford SID802 solution improved - Ford SID803 new 2 solusyon added - Ford SID803 P0490 disabled added - Ford SID803 P1412 DTC removing added - Ford SID803A added new DTCs - Ford SID803A optimized for Cmax model - Ford SID803A P2002 DTC removed problem fixed - Ford SID804 Type2 Solution added - Ford TDCI Delphi DCM32 Micro EGR removing solution has been added. - Ford Visteon 256kb type added - Ford Visteon DCU102 improved - Ford Visteon revized for also Peugeot - Hotstart Golf5 Type added new signs for different type maps - Hyundai / KIA solution totally revised. - Hyundai EDC15c7 added - Hyundai EDC16C39 Generic item added full KIA support - Improved dongle protection, added more data in dongle. - In Hyundai EDC16C39 switch solution important bug fixed - In PCR2.1 P246E DTC removing added. - Isuzu DMax Added (Aldo) - Isuzu Dmax improved with new file types - Italian language text has been revised - Italian Language totally revised, now more good - Iveco EDC16C39 EGR related DTCs automatic removing has been added - Iveco EDC16C39 revized - Jaguar Delphi DCM3.2 solution added - Jaguar SID204 solution added - Lancia 8F3 EGR removed added - Land Rover SID204 added - Land Rover SID204 bug fixed - Land Rover SID204 solution - Land Rover Visteon DCU solution added - Marelli IAW4MV solution has been added - Mazda Denso solution add signs for Mazda6 models. - Mazda EDC16C3-9 DTC's Improved - MB EDC15C6 Switch ve EGR MAP added - MB EDC16C31 1MB Type1 solution added new signs. - MB Vito solution added new sign - MB Y75 removing 512kb files bug fixed. - Mercedes B EGR Removing solution added - Mercedes DCM3.2 Micro solution added. - Mercedes DCM3.5 P0400 remove added - Mercedes Delphi DCM3.5 solution added - Mercedes Delphi DCM3.5 solution added new DTCs for removing - Mercedes EDC15C7 both solution added P1403 removing. - Mercedes EDC16 M55 fix section improved - Mercedes EDC16C02 solution more improved - Mercedes EDC16C31 - EDC16CP31 solution has been improved - Mercedes EDC16C31 1mb item now sum to in 1 one and improved. - Mercedes EDC16C31 customer DTC improved, added new signs - Mercedes EDC16C31 New models improved. - Mercedes EDC16C31 New section added some reported DTCs for other models - Mercedes EDC17C10 added - Mercedes EDC17CP10 more signs added. - Mercedes EDC17CP10 new sign added - Mercedes EDC17CP10 solution improved. - Mercedes EDC17CP11 new DTCs added - Mercedes Y75 solution new signs added - Mitsubishi Denso more DTCs added - Mitsubishi EDC16C31 solution has been added - Mitsubishi EDC16U31 added - Mitsubishi Pajero Denso EGR Removing added - Nissan Denso 1 mb and 1.5 mb file 2 solution added - Nissan Denso EGR removing has been improved - Nissan EDC16C3 added - Nissan EDC16C36 + DTCs added - Nissan EDC16CP42 EGR maps fixed - Nissan SID305 2nd P1525 DTC check - remove added - Opel Antara solution added in EDC16C39 Generic item - Opel Delco Hybrid Astra Type added - Opel Denso Astra models DTCs removing added - Opel Denso solution added. - Opel Denso solution more improved - Opel Denso solution more improved - Opel Denso Z17DTH type ECU solution has been added - Opel EDC16C39 DTC P2279 removing added - Opel EDC16C39 improved for Antara model. - Opel EDC16C39 revized switch solution - Opel EDC16C9 improved - Opel EDC16C9 new signs added - Opel EDC16C9 Signum model solution added - Opel EDC16C9 Type2 added new signs - Opel EDC16C9.23 solution new signs added - Opel EDC17C18 Added - Opel EDC17C46 Added - Opel EDC15C2 bug fixed - Opel Magneti Marelli 6f3 ECU DTC table supporting improved to all models. - Opel PSG16 sign problem has been fixed - Opel PSG16 solution added - Opel Signum3.0 Denso EGR solustion added - Opel Vectra 2.0 DTI EDC15C0 Old Model - Opel Vivaro EDC16C36 solusion revized - Opel Z13DTJ solution improved. - Packet file, encrpyted file detection added. - PCR2.1 Caddy type Egr Hysteresis map bug fixed - PCR2.1 Generic item added new soft version Golf6 file supports - PCR2.1 Generic solution important bug has been fixed - PCR2.1 Generic solution improved for Golf6 models ) - PCR2.1 generic solution maximum improved - PCR2.1 generic tuned file EGR remove problem has been fixed - PCR2.1 solution 8th map added new sign. - PCR21 Type3 signs improved to all types file - Peugeot - Renault Delphi DCM3.4 EGR removing has been added - Peugeot EDC15C2 different type signs added - Peugeot EDC16C34 Type1 P2143 DTC added - Peugeot EDC16C34 Type1 Revized - Peugeot EDC16CP39 P1445 DTC disable added - Peugeot SID803 MPC solution test byte removed - Peugeot Type1 solution P0405 DTC calculation added. - Peugeot EDC16c-7 EGR solution added. - Peugeout - Citroen EDC17CP10 Addive Pump removing added - Peugout SID801 solution has been added. - Polish language update to more good - Portuguese, Rumanian and Dutch languages some problems has been fixed. - PPD1.x EGROFF solution added - PPD1.x improved for Passat models. - Program security improved. Internal traps number now up to 289. - PSA SID803 MPC solution revized - Range Rover EDC17CP11 added, DTC's improved - Range Rover EDC17CP11 TDV6 model signs added - Range Rover SID204 DTC structures re-assembly for some models - Renault - Nissan EDC16CP33 added - Renault 1.5 CDI solustion added - Renault Delphi DCM3.4 solution added - Renault Delphi DDCR P1014 + EGR Map added - Renault EDC15C3 new signs added for EGR switches. - Renault EDC16C3-21.9 more DTCs removing added - Renault EDC16C3-9.21 added new solution for different type ECUs. - Renault EDC16C3-9.21 EGR map fill values has been set to 00 - Renault EDC16C3-9.21 revized, added full DTC's. - Renault EDC16C36 DF647 DTC removing added - Renault EDC16C36 re-improved for Injector detection problem - Renault EDC16c36 solution fixed, revized. - Renault EDC16C41 (Mascot) solution has been added - Renault EDC16C9 Full DTC removing added - Renault EDC16CP33 added - Renault EDC16CP33 improved, optimized - Renault SID305 solution added - RenaultEDC16C36 extra points added and improved - Saab EDC16C39 Remap item added P0400 DTC removing. - Saab EDC16C39 solution has been improved - SID803 MPC solution second P0409 DTC removing added - Siemens PPDv1.x Hotstart Fix added - Skoda EDC17C46 added - Skoda EDC17C46 added - Skoda EDC17U01 solution added - Smart EDC15 solution has been added - Smart EDC16C31 added. - Smart EDC16C31 Solution added - Suzuki EDC16C8 Solution2 bug has been fixed - Suzuki Vitara EDC16C3 revized - Swedish Language has been added - Toyota Denso Hilux solution has been added - Toyota Denso solution added - Toyota EDC16C31 solution has been improved - Treeview font size decreised 2 punto - Update period calculation bug has been fixed. - Vauxhall - Opel EDC17C59 solution improved - Volvo SID206 custom DTC removing support added. - Volvo SID803 MPC added - VAG EDC16U1 custom DTC calculation bug fixed. - VW - Audi EDC16U31 Type1 solution improved with new signs - VW - Audi EDC17C46 solution improved for different Audi models. - VW - Seat EDC16U34 Hotstart fix has been added - VW EDC16C34-4 Crafter solution added some new reported DTCs - VW EDC16U1 both DTC P401 added - VW EDC16U1 solution has been revised - VW EDC16U34 Caddy models P0407 removing added - VW EDC16U34 improved for Caddy models - VW EDC17C46 solution improved. - VW EDC17CP04 Solution added - VW EDC17CP52 menu bug fixed - VW ME7.5.10 ECUs EGR removing solution added (P0401 disabled) - When making Flap removing, was showing DPF removing message. All messages are fixed. Alfa : EDC16C39, EDC15C7,EDC16C8, EDC16C39 Generic Audi : EDC16U1, EDC16U31 Type1 and Typ2,EDC15VM+, EDC17CP14,PCR2.1,EDC16CP34,EDC17C46 BMW : EDC16C31 Type1 and Type2, EDC16CP35, EDC16CP35, EDC17CP02 Chrysler : EDC16CP31 Citroen : EDC16C39, EDC16C34, SID803A, EDC15C3, SID803, EDC17C10, EDC16CP39 Dodge : EDC16U31-4 Type1 and Type2 Fiat : EDC15C7, EDC16C39 Type1 and Type2, EDC16C8,Marelli MJ 70-75- 90CV,SID803A, Simos, Doblo Type Ford : EDC16C3-9, EDC16C34, Visteon, EDC16C9 Cmax Type, SID206, SID804 Honda : EDC16C31 Hyundai : EDC15C7 Lancia : EDC15C7, EDC16C39, EDC16C8,Marelli MJ 70-75-90CV,SID803A Land Rover : EDC16CP39, SID204 Iveco : EDC16C39 Isuzu : Transtron (DMax Type) Nissan : EDC16CP33,EDC16C3 Mazda : EDC16C34-2 Mercedes : EDC16C31 (1 and 2 mb types), EDC15C6 (Switch and Remap), EDC16C31 Type2,EDC16CP31 M55 Fixer, EDC17CP10, EDC16CP36 Mini Cooper : EDC16C35 Mitsubishi : EDC16U31 Opel & Vauxhall : EDC16C3,EDC16C39,EDC16C36,Marelli MJ 70-75-90CV, Z19DTH, Denso,EDC17C18,EDC17C46,Delco Peugeot : EDC16C34,EDC15C2,SID803A,EDC15C3, SID803,EDC16CP33, EDC16CP39 Range Rover : EDC17CP11 Renault : EDC16C3, EDC15C2,EDC16C3 Type2, EDC16CP36,Delphi DDCR Saab : EDC16C9 Seat : EDC16U1, EDC17CP14,PCR2.1,PPD1.x Skoda : EDC15VM+, EDC16U1, PCR2.1, PPD1.x,EDC17C46 Suzuki : Marelli MJ 70-75-90CV, EDC16C3 Volvo : EDC16, SID803, EDC17CP22 VW : EDC16U1, EDC17CP14, EDC17CP20, EDC16,PCR2.1, EDC16U34, EDC16CP34-4,PPD1.x,VW EDC17CP04 ----------------------------------- Hotstart ----------------------------------- EDC16C31, EDC16U1, EDC15, Siemens PPDv1.1 - v1.2 Special EDC15C2 - C3 switch finder ------------------------------------------------------------------ Professional Lambda Remover v2017.03 ------------------------------------------------------------------ - Audi ME7.5 - Audi ME7.5 support for other models has been improved - Audi MED17.1 P0420 CAT removing has been added - Audi Simos84 solution added - BMW MSD80 CAT removed solution added - Ford Focus ME9.0C Lambda + O2 solution added - Ford ME9.0c P0038 DTC removing added - Ford ME9.0c P0038 DTC removing added - GUI improved and languages added - Honda ME7.9.2 Lambda removing has been added - Maserati CAT OFF solution added - ME7.5 Lambda solution added - MED 7.5.11 P1070 removing added - Mercedes ME2.8 solution improved for different MB models. - Nox MED9.5.10 improved - Nox MED9.5.10 improved - Nox, O2 and CAT solutions added. - Octavia Simos 7.1A CAT - O2 removing added - Opel Corsa ME7.6.1 O2 solution added - Peugeot IAW48P O2 - CAT removing solution added - Program coded from starting, more fast and solutions more improved - PSA ME7.4.4 has been improved. - Saab Tronic 7 and 8 CAT removing added - Seat Marelli 4Mx CAT removing has been added - Seat Marelli 4Mx CAT removing has been added - Skoda MED9.5.10 - Smart ME7.7.0 solution added - Solutions included automatic DTC calculations for 0 error. - Suzuki Swift Denso CAT removing added - Swedish Language has been added - Toyota ME7.9.2 CAT removing added - Toyota ME7.9.52 signs added - Toyota ME7.9.52 signs added - Volvo Turbo Series M4.1.1 Lambda - CAT remove solution added - Volvo Turbo Series M4.1.1 Lambda - CAT remove solution added - VW Bettle Simos33 Lambda solution added - VW MED9.1 CAT improved - VW MED9.1 CAT improved - VW MED9.1 O2 - CAT removing added Alfa : ME7.3.1, ME7.3H4, ME7.9.10, MED9.5.10 Audi : ME7.1, MED9.1.1, MED9.5.10 BMW : ME9 Chrysler : ME2.8 Citroen : ME7.4.4, ME7.4.5, ME7.4.6 Dodge : ME2.8 Fiat : ME7.3H4, ME7.9.10 Ford : ME7.9 Jeep : ME2.8 Lancia : ME7.3H4 Mercedes : ME2.8, ME2.8.1 Opel : ME1.5.5, ME7.6.2 Peugout : ME7.4.4, ME7.4.5, ME7.4.6 Seat : ME7.7.10 Skoda : ME7.1 Volvo : ME7.0 XEP VW : ME7.1, ME7.5.10, MED9.1 BMW ME9 Link al commento Condividi su altri siti Altre opzioni di condivisione...
Dany88 Inviato 30 Novembre 2017 Condividi Inviato 30 Novembre 2017 quella macchina monta marelli 6jf,quindi mpps la fa,e il software funziona su quella ecu!comunque posta il file per controllo! Link al commento Condividi su altri siti Altre opzioni di condivisione...
Dany88 Inviato 30 Novembre 2017 Condividi Inviato 30 Novembre 2017 apparte questo,qui sul forum su quella ecu trovi qualsiasi info,l'eliminazione dal controllo è un solo bit! Link al commento Condividi su altri siti Altre opzioni di condivisione...
Automan Inviato 30 Novembre 2017 Autore Condividi Inviato 30 Novembre 2017 2 minuti fa, Dany88 ha scritto: apparte questo,qui sul forum su quella ecu trovi qualsiasi info,l'eliminazione dal controllo è un solo bit! Grazie, appena la leggo e la modifico posto tutto. E' da un pò che non metto mano sulle auto. Oggi un amico mi ha sollevato il problema e mi sto attivando per risolverlo rispolverando il caro vecchio mpps. Link al commento Condividi su altri siti Altre opzioni di condivisione...
