hi i need a full bdm for fiat grande punto 1.3 jtd 90hp
MJD6F3 HW03P 3144PF58    51795229
I have the ecu when i put a new file mpc and flash from MJD6F3HW04 i can connect with the car and read dtc live data everything
but when i put the mpc and the flash from MJD6F3 HW03P i cannot connect with car and is like the ecu is dead but the flash is ok the only doubt i have is the mpc and for this reason i need a full bdm
you can check here:
maybe this file can be used for your purposes.
Good Luck mate!
thx TiaGtc i have this file is the same with the file i have in the ecu and for this reason i want full bdm because i want to try to write the mpc this ecu is make me crazy when i put a flash file and mpc file from mjd6f3hw04  the ecu work.
