Lo Zio Brown Inviato 25 Novembre 2019 Inviato 25 Novembre 2019 Buongiorno a tutti . Causa errato acquisto ( e conseguente passaggio a PicoScope ) vendo oscilloscopio da pc 4 canali Hantek DSO3064 Kit VII Automotive Diagnostic Oscilloscope 4CH. e 550 Mai usato . Solo aperto la confezione per verificarne il contenuto . http://www.hantek.com/en/ProductDetail_13_53.html ModelDSO3064Vertical SystemAnalog Channels4Bandwidth60MHz(-3dB)Rise Time5.8nsInput ImpedanceResistance: 1MΩ ; Capacitance: 25 pFInput Sensitivity10mV/div to 5V/divInput CouplingAC/DC/GNDVertical Resolution8 bitsMemory Depth10K-16M/CHMaximum Input400V (DC+AC Peak)Horizontal SystemReal-Time Sampling Rate200MS/sTime Base Range5ns/div to 1000s/div(1-2-5 sequences)Time Base Precision±50ppmTrigger SystemSourceCH1, CH2,CH3,CH4,EXTModeEdge,Pulse,Viedo,AlternativeVoltage MeasurementVpp, Vamp, Vmax, Vmin, Vtop, Vmid, Vbase, Vavg, Vrms, Vcrms, Preshoot, Overshoot, Frequency, Period, Rise Time, Fall Time, Positive Width, Negative Width, Duty CycleCursors MeasurementHorizontal ,Vertical, Track, Auto Measure ModesWaveform Signal Process+,- , x,÷, FFT, InvertVoltage Range 10mV to 5V/div @ x 1 probe; 100mV to 50V/div @ x 10 probe; 1V to 500V/div @ x 100 probe; 10V to 5000V/div @ x 1000 probe; 100V to 50000V/div @ x 10000 probe; 200mV to 100V/div @ 20:1Current RangeCC65(20A),CC65(60A),CC650,CC1100FFTRectangular,Hanning,Hamming,Blackman WindowMathAdition,subtraction,multiplication,divisionGennral Feature InterfaceUSB 2.0(Lan Optional) Power Source8--36V Wide range of input voltageVolume490 x 165 x 410 (mm)Weight8 KgPacking Case Aluminum case Auto Test Cable (HT30A) 4 Auto High-Pressure Ignition Probe (HT25) 420:1 Attenuator (HT201) 4Large Dolphin/Gator Clip (HT18A) 4Multimeter Probe (HT19) 4Acupuncture Probe Set (HT307) 1Dolphin/Gator Clip Cable (HT324) 2Break Out Leads (HT301) 1 Coil-on-Plug Extension Cord (with earth cord) (HT308) 4Auto Power Adapter (HT310) 1CC65 Current Clamp 1CC650 Current Clamp
Lo Zio Brown Inviato 26 Novembre 2019 Autore Inviato 26 Novembre 2019 euro 550 . sono di Baveno provincia Verbania sul lago maggiore sponda piemontese
