Pagamenti: RISOLTO
Email: BLOCCATE
Servizio file tuning: ATTIVO
Contattaci su WhatsApp
EDC17C64 - 2.0 TDI Mappe pressione turbo
Ciao Ragazzi,
chi mi può aiutare a capire i seguenti indirizzi su edc17c64 come influenzano la pressione turbo? Vanno modificate in punti o in %? è sempre necessario modificarle?
Allego le descrizioni Damos...Grazie
$2FC8BA map of desired value for combustion-chamber-charge DATA_GEC_DesBas_mCh.GEC_mChBasInj0Bm00_M_VW 16x16
$2FCD32 map of desired value for combustion-chamber-charge DATA_GEC_DesBas_mCh.GEC_mChBasInj0Bm02_M_VW 12x12
$2FCE86 map of desired value for combustion-chamber-charge DATA_GEC_DesBas_mCh.GEC_mChBasInj0Bm03_M_VW 12x12
$2FCFE8 map of desired value for combustion-chamber-charge DATA_GEC_DesBas_mCh.GEC_mChBasInj0Bm04_M_VW 16x15
$2FD21E map of desired value for combustion-chamber-charge DATA_GEC_DesBas_mCh.GEC_mChBasInj0Bm05_M_VW 12x12
$2FD382 map of desired value for combustion-chamber-charge DATA_GEC_DesBas_mCh.GEC_mChBasInj0Bm06_M_VW 16x16
$2FD5DA map of desired value for combustion-chamber-charge DATA_GEC_DesBas_mCh.GEC_mChBasInj0Bm08_M_VW 16x16
$2FD81E map of desired value for combustion-chamber-charge DATA_GEC_DesBas_mCh.GEC_mChBasInj0Bm09_M_VW 16x16
$2FDB7E map of desired value for combustion-chamber-charge DATA_GEC_DesBas_mCh.GEC_mChBasInj0Bm13_M_VW 16x16
$2FE954 map of desired value for combustion-chamber-charge DATA_GEC_DesBas_mCh.GEC_mChBasInj1Bm03_M_VW 12x12
$2FECEC map of desired value for combustion-chamber-charge DATA_GEC_DesBas_mCh.GEC_mChBasInj1Bm05_M_VW 12x12
$308B5C combustion-chamber-charge map depending on torque DATA_GEC_DesCor0_mCh.GEC_mChCor0MapBm00_M_VW 16x16
$30B948 map for the correction due to altitude of combustion-chamber-charge DATA_GEC_DesCor1_mCh.GEC_mChCor1Bm00_M_VW 16x16
$30BB8C map for the correction due to altitude of combustion-chamber-charge DATA_GEC_DesCor1_mCh.GEC_mChCor1Bm01_M_VW 16x16
$30BDB0 map for the correction due to altitude of combustion-chamber-charge DATA_GEC_DesCor1_mCh.GEC_mChCor1Bm02_M_VW 8x8
$30BE64 map for the correction due to altitude of combustion-chamber-charge DATA_GEC_DesCor1_mCh.GEC_mChCor1Bm03_M_VW 12x12
$30BFC6 map for the correction due to altitude of combustion-chamber-charge DATA_GEC_DesCor1_mCh.GEC_mChCor1Bm04_M_VW 16x15
$30C1FC map for the correction due to altitude of combustion-chamber-charge DATA_GEC_DesCor1_mCh.GEC_mChCor1Bm05_M_VW 12x12
$30C360 map for the correction due to altitude of combustion-chamber-charge DATA_GEC_DesCor1_mCh.GEC_mChCor1Bm06_M_VW 16x16
$30C5B8 map for the correction due to altitude of combustion-chamber-charge DATA_GEC_DesCor1_mCh.GEC_mChCor1Bm7_M_VW 16x16
Allora le mappe che hai elencato: map of desired value for combustion-chamber-charge non sono altro che le mappe pressione turbo, su edc17c64 e 74 non abbiamo più le classiche mappe in mBar ma abbiamo i mg aria, io ti consiglio su questa tipologia di ecu di dare un 6% che corrisponde a circa 0.15/0.17 bar
I limitatori sono questi: reference map for limitation of the boost pressure for overspeed protection DATA_GEC_CordLim_rTvh.GEC_pCmprRefMaxBm00_M_VW
le altre lasciale stare
Modificato da psim
  • Thanks 1
Grazie mille per il chiarimento! gentilissimo come sempre.
Volevo dirti che modificando la mappa con +6% l'auto va benissimo e sopratutto non strattona piu.
Sapresti dirmi perchè superando il 10% di incremento l'auto ha dei vuoti e tende a strappare in basso?
sinceramente non saprei il motivo io sull'unica c74 che ho fatto non ho dato più di 8% ed è senza fap, dovrei essere sui 220cv da 184 di serie
allora probabilmente è una questione di carico.
Nell'esempio in allegato, ho inserito una delle mappe turbo modificata al +6%.
E' corretto moddarla cosi? O bisogna partire da un numero di giri più alto?
6 minuti fa, psim ha scritto:
Io in genere parto da poco meno di metà mappa, da 120Nm in poi 1500rpm in su
quindi asse Y = carico pedale, asse X = Giri motore (RPM)?
Corretto?
Esatto, dipende da come la giri con winols perché invertire gli assi, io di solito lavoro con Nm sulle colonne e rpm come righe
Perfetto, quindi ogni mappa è a se stante, da 0 a n rpm (asse X) e da 0 a n nm (asse Y), immagino quindi che siano tutte affini come mappe.
