Alfa 156 TS - where is location of second key in immo dump.
hi,
- I'll has dump from immo box D6/V1 p/n 606 53 687 alfa romeo 156 ts '2000
- car has programming two keys.
- first in this photo, but where is second key in this dump of immo box ?
- for first key , i'll calculate PIN,
- and still looking where is second key in this dump.
- If i'll be know two key and his PIN , i must do procedure immo-off from this ECU.
- two way to make immo-off from ECu is reprogram immo box, delete two key and programming for know PIN, next program transponder and in last used Galletto 12.50 to reprogram ECU.
- but for this all step MUST know where is location second key.
PIN for this first key is 89461.
there in the file written log in micro and you unlock it with a program and you must first put the boot in micro hello
You must do this because that type of power laid up when you do not write eprom and you can not write the file in order to unlock once written to the file you unlock what you want hello
euroscan
per eliminare code tutte le 1.55 trova il valoe 2525 e portalo DBDB poi fai il cecsam ed il gioco e' fatto saluti giuseppe
