michass Inviato 15 Febbraio 2023 Inviato 15 Febbraio 2023 Hi, I have Giulietta 1.4 MA 8GMK 50hp manual. I do modifications to 200hp/300nm with stock cat euro6. I have mentioned issues: - I have problem with ignition angle factor. Normal Marelli 8GM/ 10J have factor 0.0625, my has something about 0,003125, can someone confirm this value? - I cant prepare proper Pops and Bangs. when i extend cutoff delay i cant relearn phonic wheel. - I can't find solution for bigger injectors scaling. If someone want xdf file for this ECU, i can release.
Ospite Inviato 11 Gennaio 2024 Inviato 11 Gennaio 2024 hi, if you need still, on the other forum there is a2l file for your project ...
michass Inviato 23 Febbraio 2024 Autore Inviato 23 Febbraio 2024 On 1/11/2024 at 3:47 PM, JoyHF said: hi, if you need still, on the other forum there is a2l file for your project ... Can you send me file or location of another forum?
Ospite Inviato 27 Febbraio 2024 Inviato 27 Febbraio 2024 try on digitalkaos, nefmoto, ecuconnections ...
