PHP logo
PHP Version 8.1.30
System Linux node36006-etpsolutions.it1.eur.aruba.jenv-aruba.cloud 5.14.0 #1 SMP Wed Jul 12 12:00:44 MSK 2023 x86_64
Build Date Sep 27 2024 12:51:38
Build System Linux buildkitsandbox 5.4.0 #1 SMP Tue Jan 9 19:45:01 MSK 2024 x86_64 x86_64 x86_64 GNU/Linux
Configure Command './configure' '--bindir=/usr/bin' '--build=x86_64-redhat-linux-gnu' '--disable-debug' '--disable-rpath' '--enable-bcmath=shared' '--enable-calendar=shared' '--enable-dba=shared' '--enable-dom=shared' '--enable-exif=shared' '--enable-fileinfo=shared' '--enable-ftp=shared' '--enable-fpm' '--enable-gd=shared' '--enable-gd-native-ttf' '--enable-json=shared' '--enable-libxml' '--enable-mbstring=shared,all' '--enable-mysqlnd=shared' '--enable-pcntl=shared' '--enable-pdo=shared' '--enable-phar=shared' '--enable-posix=shared' '--enable-shared' '--enable-shmop=shared' '--enable-simplexml=shared' '--enable-soap=shared' '--enable-sockets' '--enable-sysvsem=shared' '--enable-sysvshm=shared' '--enable-tokenizer=shared' '--enable-wddx=shared' '--enable-xml' '--enable-xmlreader=shared' '--enable-xmlwriter=shared' '--enable-zip=shared' '--exec-prefix=/usr' '--host=x86_64-redhat-linux-gnu' '--libdir=/usr/lib64' '--prefix=/usr' '--program-prefix=' '--sbindir=/usr/sbin' '--target=x86_64-redhat-linux-gnu' '--with-apxs2=/bin/apxs' '--with-bz2=shared' '--with-config-file-path=/etc' '--with-config-file-scan-dir=/etc/php.d' '--with-ctype=shared' '--with-curl=shared' '--with-freetype' '--with-freetype-dir=/usr' '--with-freetype-dir=/usr/include/freetype2/freetype' '--with-gd=shared' '--with-gettext=shared' '--with-gmp=shared' '--with-iconv=shared' '--with-imap=shared' '--with-imap-ssl' '--with-jpeg-dir' '--with-jpeg-dir=/usr' '--with-kerberos' '--with-layout=GNU' '--with-ldap=shared' '--with-libdir=lib64' '--with-libxml-dir=/usr' '--with-mhash' '--with-mysqli=shared' '--with-mysql=shared' '--with-openssl=shared' '--without-gdbm' '--without-sqlite' '--with-password-argon2' '--with-pdo-firebird=shared' '--with-pdo-mysql=shared' '--with-pdo-pgsql=shared,/usr/pgsql-13' '--with-pdo-sqlite=shared,/usr' '--with-pear' '--with-pgsql=shared,/usr/pgsql-13' '--with-pic' '--with-png-dir' '--with-png-dir=/usr' '--with-pspell=shared' '--with-snmp=shared' '--with-sqlite3=shared' '--with-tidy=shared' '--with-unixODBC=shared,/usr' '--with-webp-dir=/usr/include/webp' '--with-xmlrpc=shared' '--with-xpm-dir' '--with-xsl=shared' '--with-zlib-dir' '--with-zlib=shared' '--enable-zts' 'build_alias=x86_64-redhat-linux-gnu' 'host_alias=x86_64-redhat-linux-gnu' 'target_alias=x86_64-redhat-linux-gnu'
Server API Apache 2.0 Handler
Virtual Directory Support enabled
Configuration File (php.ini) Path /etc
Loaded Configuration File /etc/php.ini
Scan this dir for additional .ini files /etc/php.d
Additional .ini files parsed /etc/php.d/error-log.ini
PHP API 20210902
PHP Extension 20210902
Zend Extension 420210902
Zend Extension Build API420210902,TS
PHP Extension Build API20210902,TS
Debug Build no
Thread Safety enabled
Thread API POSIX Threads
Zend Signal Handling enabled
Zend Memory Manager enabled
Zend Multibyte Support provided by mbstring
Zend Max Execution Timers disabled
IPv6 Support enabled
DTrace Support disabled
Registered PHP Streamsphp, file, glob, data, http, ftp, compress.bzip2, https, ftps, compress.zlib, zip, phar
Registered Stream Socket Transportstcp, udp, unix, udg, ssl, tls, tlsv1.0, tlsv1.1, tlsv1.2, tlsv1.3
Registered Stream Filtersstring.rot13, string.toupper, string.tolower, convert.*, consumed, dechunk, bzip2.*, convert.iconv.*, mcrypt.*, mdecrypt.*, zlib.*
Zend logo This program makes use of the Zend Scripting Language Engine:
Zend Engine v4.1.30, Copyright (c) Zend Technologies
Configuration
apache2handler
Apache Version Apache
Apache API Version 20120211
Server Administrator admin@etpsolutions.com
Hostname:Port www.etpsolutions.com:443
User/Group apache(700)/700
Max Requests Per Child: 500 - Keep Alive: off - Max Per Connection: 100
Timeouts Connection: 120 - Keep-Alive: 15
Virtual Server Yes
Server Root /etc/httpd
Loaded Modules core mod_so http_core mod_access_compat mod_actions mod_alias mod_allowmethods mod_auth_basic mod_auth_digest mod_authn_anon mod_authn_core mod_authn_dbd mod_authn_dbm mod_authn_file mod_authn_socache mod_authnz_fcgi mod_authz_core mod_authz_dbd mod_authz_dbm mod_authz_groupfile mod_authz_host mod_authz_owner mod_authz_user mod_autoindex mod_cache mod_cache_disk mod_cache_socache mod_data mod_dbd mod_deflate mod_dir mod_dumpio mod_echo mod_env mod_expires mod_ext_filter mod_filter mod_headers mod_include mod_info mod_log_config mod_logio mod_macro mod_mime_magic mod_mime mod_negotiation mod_remoteip mod_reqtimeout mod_request mod_rewrite mod_setenvif mod_slotmem_plain mod_slotmem_shm mod_socache_dbm mod_socache_memcache mod_socache_redis mod_socache_shmcb mod_status mod_substitute mod_suexec mod_unique_id mod_unixd mod_userdir mod_version mod_vhost_alias mod_watchdog mod_dav mod_dav_fs mod_dav_lock mod_lua prefork mod_proxy mod_lbmethod_bybusyness mod_lbmethod_byrequests mod_lbmethod_bytraffic mod_lbmethod_heartbeat mod_proxy_ajp mod_proxy_balancer mod_proxy_connect mod_proxy_express mod_proxy_fcgi mod_proxy_fdpass mod_proxy_ftp mod_proxy_http mod_proxy_hcheck mod_proxy_scgi mod_proxy_uwsgi mod_proxy_wstunnel mod_systemd mod_cgi mod_realdoc mod_usertrack mod_speling mod_asis mod_ssl mod_php mod_http2
DirectiveLocal ValueMaster Value
engineOnOn
last_modifiedOffOff
xbithackOffOff
Apache Environment
VariableValue
REDIRECT_UNIQUE_ID Z0D0XR6ANyADrQIM3_C6mAAAAAM
REDIRECT_HTTPS on
REDIRECT_SSL_TLS_SNI etpsolutions.com
REDIRECT_STATUS 200
HTTPS on
HTTP_ACCEPT */*
HTTP_USER_AGENT Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com)
HTTP_COOKIE handl_ip=18.189.185.63; handl_url=https%3A%2F%2Fswift-cut.com%2F2018%2F10%2F5mm-aluminium-45-amps%2F4%2F; user_agent=Mozilla%2F5.0%20AppleWebKit%2F537.36%20%28KHTML%2C%20like%20Gecko%3B%20compatible%3B%20ClaudeBot%2F1.0%3B%20%2Bclaudebot%40anthropic.com%29; handl_landing_page=https%3A%2F%2Fswift-cut.com%2F2018%2F10%2F5mm-aluminium-45-amps%2F4; handl_ref=https%3A%2F%2Fswift-cut.com%2Ffr%2F2018%2F10%2F5mm-aluminium-45-amps%2F4; HandLtestDomainNameServer=HandLtestDomainValueServer; handl_url_base=https%3A%2F%2Fswift-cut.com%2F2018%2F10%2F5mm-aluminium-45-amps%2F4%2F; organic_source_str=Internal; organic_source=https%3A%2F%2Fswift-cut.com%2Ffr%2F2018%2F10%2F5mm-aluminium-45-amps%2F4; handl_original_ref=https%3A%2F%2Fswift-cut.com%2Ffr%2F2018%2F10%2F5mm-aluminium-45-amps%2F4
HTTP_ACCEPT_ENCODING gzip, br, zstd, deflate
HTTP_HOST etpsolutions.com
PATH /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
SERVER_SIGNATURE no value
SERVER_SOFTWARE Apache
SERVER_NAME etpsolutions.com
SERVER_ADDR 95.110.177.123
SERVER_PORT 443
REMOTE_ADDR 18.189.185.63
DOCUMENT_ROOT /var/www/webroot/ROOT
REQUEST_SCHEME https
CONTEXT_PREFIX no value
CONTEXT_DOCUMENT_ROOT /var/www/webroot/ROOT
SERVER_ADMIN admin@etpsolutions.com
SCRIPT_FILENAME /var/www/webroot/ROOT/index.php
REMOTE_PORT 7283
REDIRECT_URL /forums/topic/8775-cerco-ori-nuova-fiesta-16-tdci-90cv-fap
GATEWAY_INTERFACE CGI/1.1
SERVER_PROTOCOL HTTP/1.1
REQUEST_METHOD GET
QUERY_STRING no value
REQUEST_URI /forums/topic/8775-cerco-ori-nuova-fiesta-16-tdci-90cv-fap
SCRIPT_NAME /index.php
HTTP Headers Information
HTTP Request Headers
HTTP Request GET /forums/topic/8775-cerco-ori-nuova-fiesta-16-tdci-90cv-fap HTTP/1.1
accept */*
user-agent Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com)
cookie handl_ip=18.189.185.63; handl_url=https%3A%2F%2Fswift-cut.com%2F2018%2F10%2F5mm-aluminium-45-amps%2F4%2F; user_agent=Mozilla%2F5.0%20AppleWebKit%2F537.36%20%28KHTML%2C%20like%20Gecko%3B%20compatible%3B%20ClaudeBot%2F1.0%3B%20%2Bclaudebot%40anthropic.com%29; handl_landing_page=https%3A%2F%2Fswift-cut.com%2F2018%2F10%2F5mm-aluminium-45-amps%2F4; handl_ref=https%3A%2F%2Fswift-cut.com%2Ffr%2F2018%2F10%2F5mm-aluminium-45-amps%2F4; HandLtestDomainNameServer=HandLtestDomainValueServer; handl_url_base=https%3A%2F%2Fswift-cut.com%2F2018%2F10%2F5mm-aluminium-45-amps%2F4%2F; organic_source_str=Internal; organic_source=https%3A%2F%2Fswift-cut.com%2Ffr%2F2018%2F10%2F5mm-aluminium-45-amps%2F4; handl_original_ref=https%3A%2F%2Fswift-cut.com%2Ffr%2F2018%2F10%2F5mm-aluminium-45-amps%2F4
accept-encoding gzip, br, zstd, deflate
host etpsolutions.com
HTTP Response Headers
Upgrade h2
Connection Upgrade
bcmath
BCMath support enabled
bcmath.scale00
bz2
BZip2 Support Enabled
Stream Wrapper support compress.bzip2://
Stream Filter support bzip2.decompress, bzip2.compress
BZip2 Version 1.0.8, 13-Jul-2019
calendar
Calendar support enabled
Core
PHP Version 8.1.30
allow_url_fopenOnOn
allow_url_includeOffOff
arg_separator.input&&
arg_separator.output&&
auto_append_fileno valueno value
auto_globals_jitOnOn
auto_prepend_fileno valueno value
browscapno valueno value
default_charsetUTF-8UTF-8
default_mimetypetext/htmltext/html
disable_classesno valueno value
disable_functionsno valueno value
display_errorsOffOff
display_startup_errorsOffOff
doc_rootno valueno value
docref_extno valueno value
docref_rootno valueno value
enable_dlOffOff
enable_post_data_readingOnOn
error_append_stringno valueno value
error_log/var/log/httpd/php_errors.log/var/log/httpd/php_errors.log
error_prepend_stringno valueno value
error_reporting3276732767
expose_phpOffOff
extension_dir/usr/lib64/php/modules/usr/lib64/php/modules
fiber.stack_sizeno valueno value
file_uploadsOnOn
hard_timeout22
highlight.comment#FF8000#FF8000
highlight.default#0000BB#0000BB
highlight.html#000000#000000
highlight.keyword#007700#007700
highlight.string#DD0000#DD0000
html_errorsOnOn
ignore_repeated_errorsOnOn
ignore_repeated_sourceOnOn
ignore_user_abortOnOn
implicit_flushOffOff
include_path.:/usr/share/pear.:/usr/share/pear
input_encodingno valueno value
internal_encodingno valueno value
log_errorsOnOn
mail.add_x_headerOnOn
mail.force_extra_parametersno valueno value
mail.log/var/log/httpd/sendmail.log/var/log/httpd/sendmail.log
max_execution_time300300
max_file_uploads2020
max_input_nesting_level6464
max_input_time6060
max_input_vars10001000
max_multipart_body_parts-1-1
memory_limit256M256M
open_basedirno valueno value
output_buffering40964096
output_encodingno valueno value
output_handlerno valueno value
post_max_size100M100M
precision1414
realpath_cache_size4096K4096K
realpath_cache_ttl120120
register_argc_argvOnOn
report_memleaksOnOn
report_zend_debugOffOff
request_orderGPGP
sendmail_fromno valueno value
sendmail_path/usr/sbin/sendmail -t -i/usr/sbin/sendmail -t -i
serialize_precision1717
short_open_tagOnOn
SMTPlocalhostlocalhost
smtp_port2525
sys_temp_dirno valueno value
syslog.facilityLOG_USERLOG_USER
syslog.filterno-ctrlno-ctrl
syslog.identphpphp
unserialize_callback_funcno valueno value
upload_max_filesize100M100M
upload_tmp_dirno valueno value
user_dirno valueno value
user_ini.cache_ttl300300
user_ini.filename.user.ini.user.ini
variables_orderGPCSGPCS
xmlrpc_error_number00
xmlrpc_errorsOffOff
zend.assertions11
zend.detect_unicodeOnOn
zend.enable_gcOnOn
zend.exception_ignore_argsOffOff
zend.exception_string_param_max_len1515
zend.multibyteOffOff
zend.script_encodingno valueno value
zend.signal_checkOffOff
ctype
ctype functions enabled
curl
cURL support enabled
cURL Information 7.76.1
Age 8
Features
AsynchDNS Yes
CharConv No
Debug No
GSS-Negotiate No
IDN No
IPv6 Yes
krb4 No
Largefile Yes
libz Yes
NTLM Yes
NTLMWB No
SPNEGO Yes
SSL Yes
SSPI No
TLS-SRP No
HTTP2 Yes
GSSAPI Yes
KERBEROS5 Yes
UNIX_SOCKETS Yes
PSL No
HTTPS_PROXY Yes
MULTI_SSL No
BROTLI No
Protocols file, ftp, ftps, http, https
Host x86_64-redhat-linux-gnu
SSL Version OpenSSL/3.0.7
ZLib Version 1.2.11
curl.cainfono valueno value
date
date/time support enabled
timelib version 2021.19
"Olson" Timezone Database Version 2023.3
Timezone Database internal
Default timezone UTC
date.default_latitude31.766731.7667
date.default_longitude35.233335.2333
date.sunrise_zenith90.83333390.833333
date.sunset_zenith90.83333390.833333
date.timezoneUTCUTC
dba
DBA support enabled
Supported handlers cdb cdb_make inifile flatfile
dba.default_handlerflatfileflatfile
dom
DOM/XML enabled
DOM/XML API Version 20031129
libxml Version 2.9.13
HTML Support enabled
XPath Support enabled
XPointer Support enabled
Schema Support enabled
RelaxNG Support enabled
exif
EXIF Support enabled
Supported EXIF Version 0220
Supported filetypes JPEG, TIFF
Multibyte decoding support using mbstring enabled
Extended EXIF tag formats Canon, Casio, Fujifilm, Nikon, Olympus, Samsung, Panasonic, DJI, Sony, Pentax, Minolta, Sigma, Foveon, Kyocera, Ricoh, AGFA, Epson
exif.decode_jis_intelJISJIS
exif.decode_jis_motorolaJISJIS
exif.decode_unicode_intelUCS-2LEUCS-2LE
exif.decode_unicode_motorolaUCS-2BEUCS-2BE
exif.encode_jisno valueno value
exif.encode_unicodeISO-8859-15ISO-8859-15
fileinfo
fileinfo support enabled
libmagic 540
filter
Input Validation and Filtering enabled
filter.defaultunsafe_rawunsafe_raw
filter.default_flagsno valueno value
ftp
FTP support enabled
FTPS support enabled
gettext
GetText Support enabled
gmp
gmp support enabled
GMP version 6.2.0
hash
hash support enabled
Hashing Engines md2 md4 md5 sha1 sha224 sha256 sha384 sha512/224 sha512/256 sha512 sha3-224 sha3-256 sha3-384 sha3-512 ripemd128 ripemd160 ripemd256 ripemd320 whirlpool tiger128,3 tiger160,3 tiger192,3 tiger128,4 tiger160,4 tiger192,4 snefru snefru256 gost gost-crypto adler32 crc32 crc32b crc32c fnv132 fnv1a32 fnv164 fnv1a64 joaat murmur3a murmur3c murmur3f xxh32 xxh64 xxh3 xxh128 haval128,3 haval160,3 haval192,3 haval224,3 haval256,3 haval128,4 haval160,4 haval192,4 haval224,4 haval256,4 haval128,5 haval160,5 haval192,5 haval224,5 haval256,5
MHASH support Enabled
MHASH API Version Emulated Support
iconv
iconv support enabled
iconv implementation glibc
iconv library version 2.34
iconv.input_encodingno valueno value
iconv.internal_encodingno valueno value
iconv.output_encodingno valueno value
json
json support enabled
libxml
libXML support active
libXML Compiled Version 2.9.13
libXML Loaded Version 20913
libXML streams enabled
mbstring
Multibyte Support enabled
Multibyte string engine libmbfl
HTTP input encoding translation enabled
libmbfl version 1.3.2
mbstring extension makes use of "streamable kanji code filter and converter", which is distributed under the GNU Lesser General Public License version 2.1.
Multibyte (japanese) regex support enabled
Multibyte regex (oniguruma) version 6.9.6
mbstring.detect_orderno valueno value
mbstring.encoding_translationOnOn
mbstring.http_inputno valueno value
mbstring.http_outputno valueno value
mbstring.http_output_conv_mimetypes^(text/|application/xhtml\+xml)^(text/|application/xhtml\+xml)
mbstring.internal_encodingno valueno value
mbstring.languageNeutralNeutral
mbstring.regex_retry_limit10000001000000
mbstring.regex_stack_limit100000100000
mbstring.strict_detectionOffOff
mbstring.substitute_characterno valueno value
mcrypt
mcrypt supportenabled
mcrypt_filter supportenabled
Extension version 1.0.7
Library version 2.5.8
Api No 20021217
Supported ciphers cast-128 gost rijndael-128 twofish arcfour cast-256 loki97 rijndael-192 saferplus wake blowfish-compat des rijndael-256 serpent xtea blowfish enigma rc2 tripledes
Supported modes cbc cfb ctr ecb ncfb nofb ofb stream
mcrypt.algorithms_dirno valueno value
mcrypt.modes_dirno valueno value
memcached
memcached supportenabled
Version 3.2.0
libmemcached-awesome version 1.1.0
SASL support yes
Session support yes
igbinary support no
json support no
msgpack support no
memcached.compression_factor1.31.3
memcached.compression_threshold20002000
memcached.compression_typefastlzfastlz
memcached.default_binary_protocolOffOff
memcached.default_connect_timeout00
memcached.default_consistent_hashOffOff
memcached.serializerphpphp
memcached.sess_binary_protocolOnOn
memcached.sess_connect_timeout10001000
memcached.sess_consistent_hashOnOn
memcached.sess_consistent_hash_typeketamaketama
memcached.sess_lock_expire00
memcached.sess_lock_max_waitnot setnot set
memcached.sess_lock_retries55
memcached.sess_lock_waitnot setnot set
memcached.sess_lock_wait_max150150
memcached.sess_lock_wait_min150150
memcached.sess_lockingOnOn
memcached.sess_number_of_replicas00
memcached.sess_persistentOffOff
memcached.sess_prefixmemc.sess.key.memc.sess.key.
memcached.sess_randomize_replica_readOffOff
memcached.sess_remove_failed_serversOffOff
memcached.sess_sasl_passwordno valueno value
memcached.sess_sasl_usernameno valueno value
memcached.sess_server_failure_limit00
memcached.store_retry_count22
mysqli
MysqlI Supportenabled
Client API library version mysqlnd 8.1.30
Active Persistent Links 0
Inactive Persistent Links 0
Active Links 0
mysqli.allow_local_infileOffOff
mysqli.allow_persistentOnOn
mysqli.default_hostno valueno value
mysqli.default_port33063306
mysqli.default_pwno valueno value
mysqli.default_socketno valueno value
mysqli.default_userno valueno value
mysqli.local_infile_directoryno valueno value
mysqli.max_linksUnlimitedUnlimited
mysqli.max_persistentUnlimitedUnlimited
mysqli.reconnectOffOff
mysqli.rollback_on_cached_plinkOffOff
mysqlnd
mysqlndenabled
Version mysqlnd 8.1.30
Compression supported
core SSL supported
extended SSL supported
Command buffer size 4096
Read buffer size 32768
Read timeout 31536000
Collecting statistics Yes
Collecting memory statistics Yes
Tracing no value
Loaded plugins mysqlnd,debug_trace,auth_plugin_mysql_native_password,auth_plugin_mysql_clear_password,auth_plugin_caching_sha2_password,auth_plugin_sha256_password
API Extensions mysqli,pdo_mysql
openssl
OpenSSL support enabled
OpenSSL Library Version OpenSSL 3.0.7 1 Nov 2022
OpenSSL Header Version OpenSSL 3.0.7 1 Nov 2022
Openssl default config /etc/pki/tls/openssl.cnf
openssl.cafileno valueno value
openssl.capathno valueno value
pcntl
pcntl supportenabled
pcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 10.39 2021-10-29
PCRE Unicode Version 14.0.0
PCRE JIT Support enabled
PCRE JIT Target x86 64bit (little endian + unaligned)
pcre.backtrack_limit10000001000000
pcre.jit11
pcre.recursion_limit100000100000
PDO
PDO supportenabled
PDO drivers firebird, mysql, pgsql, sqlite
PDO_Firebird
PDO Driver for Firebirdenabled
Client Library Version LI-V6.3.0.2496 Firebird 4.0
pdo_mysql
PDO Driver for MySQLenabled
Client API version mysqlnd 8.1.30
pdo_mysql.default_socket/var/lib/mysql/mysql.sock/var/lib/mysql/mysql.sock
pdo_pgsql
PDO Driver for PostgreSQL enabled
PostgreSQL(libpq) Version 13.16
pdo_sqlite
PDO Driver for SQLite 3.xenabled
SQLite Library 3.34.1
Phar
Phar: PHP Archive supportenabled
Phar API version 1.1.1
Phar-based phar archives enabled
Tar-based phar archives enabled
ZIP-based phar archives enabled
gzip compression enabled
bzip2 compression enabled
Phar based on pear/PHP_Archive, original concept by Davey Shafik.
Phar fully realized by Gregory Beaver and Marcus Boerger.
Portions of tar implementation Copyright (c) 2003-2009 Tim Kientzle.
phar.cache_listno valueno value
phar.readonlyOnOn
phar.require_hashOnOn
posix
POSIX support enabled
pspell
PSpell Support enabled
raphf
Resource and persistent handle factory supportenabled
Extension version 2.0.1
Persistent handles in this thread
ProviderIdentUsedFree
raphf.persistent_handle.limit-1-1
Reflection
Reflection enabled
session
Session Support enabled
Registered save handlers files user memcached
Registered serializer handlers php_serialize php php_binary
session.auto_startOffOff
session.cache_expire180180
session.cache_limiternocachenocache
session.cookie_domainno valueno value
session.cookie_httponlyno valueno value
session.cookie_lifetime00
session.cookie_path//
session.cookie_samesiteno valueno value
session.cookie_secure00
session.gc_divisor10001000
session.gc_maxlifetime14401440
session.gc_probability11
session.lazy_writeOnOn
session.namePHPSESSIDPHPSESSID
session.referer_checkno valueno value
session.save_handlermemcachedmemcached
session.save_path172.16.107.229:11211172.16.107.229:11211
session.serialize_handlerphpphp
session.sid_bits_per_character44
session.sid_length3232
session.upload_progress.cleanupOnOn
session.upload_progress.enabledOnOn
session.upload_progress.freq1%1%
session.upload_progress.min_freq11
session.upload_progress.namePHP_SESSION_UPLOAD_PROGRESSPHP_SESSION_UPLOAD_PROGRESS
session.upload_progress.prefixupload_progress_upload_progress_
session.use_cookies11
session.use_only_cookies11
session.use_strict_modeno valueno value
session.use_trans_sid00
shmop
shmop support enabled
SimpleXML
SimpleXML support enabled
Schema support enabled
sockets
Sockets Support enabled
SPL
SPL supportenabled
Interfaces OuterIterator, RecursiveIterator, SeekableIterator, SplObserver, SplSubject
Classes AppendIterator, ArrayIterator, ArrayObject, BadFunctionCallException, BadMethodCallException, CachingIterator, CallbackFilterIterator, DirectoryIterator, DomainException, EmptyIterator, FilesystemIterator, FilterIterator, GlobIterator, InfiniteIterator, InvalidArgumentException, IteratorIterator, LengthException, LimitIterator, LogicException, MultipleIterator, NoRewindIterator, OutOfBoundsException, OutOfRangeException, OverflowException, ParentIterator, RangeException, RecursiveArrayIterator, RecursiveCachingIterator, RecursiveCallbackFilterIterator, RecursiveDirectoryIterator, RecursiveFilterIterator, RecursiveIteratorIterator, RecursiveRegexIterator, RecursiveTreeIterator, RegexIterator, RuntimeException, SplDoublyLinkedList, SplFileInfo, SplFileObject, SplFixedArray, SplHeap, SplMinHeap, SplMaxHeap, SplObjectStorage, SplPriorityQueue, SplQueue, SplStack, SplTempFileObject, UnderflowException, UnexpectedValueException
sqlite3
SQLite3 supportenabled
sqlite3.defensiveOnOn
sqlite3.extension_dirno valueno value
standard
Dynamic Library Support enabled
Path to sendmail /usr/sbin/sendmail -t -i
assert.activeOnOn
assert.bailOffOff
assert.callbackno valueno value
assert.exceptionOnOn
assert.warningOnOn
auto_detect_line_endingsOffOff
default_socket_timeout6060
session.trans_sid_hostsno valueno value
session.trans_sid_tagsa=href,area=href,frame=src,form=a=href,area=href,frame=src,form=
unserialize_max_depth40964096
url_rewriter.hostsno valueno value
url_rewriter.tagsa=href,area=href,frame=src,input=src,form=fakeentrya=href,area=href,frame=src,input=src,form=fakeentry
user_agentPHPPHP
sysvsem
sysvsem support enabled
sysvshm
sysvshm support enabled
tidy
Tidy support enabled
libTidy Version 5.8.0
libTidy Release 2021/07/10
tidy.clean_output00
tidy.default_configno valueno value
tokenizer
Tokenizer Support enabled
xml
XML Support active
XML Namespace Support active
libxml2 Version 2.9.13
xmlreader
XMLReader enabled
xmlwriter
XMLWriter enabled
zip
Zip enabled
Zip version 1.19.5
Libzip version 1.7.3
BZIP2 compression Yes
XZ compression Yes
ZSTD compression No
AES-128 encryption Yes
AES-192 encryption Yes
AES-256 encryption Yes
zlib
ZLib Supportenabled
Stream Wrapper compress.zlib://
Stream Filter zlib.inflate, zlib.deflate
Compiled Version 1.2.11
Linked Version 1.2.11
zlib.output_compressionOffOff
zlib.output_compression_level-1-1
zlib.output_handlerno valueno value
Additional Modules
Module Name
Environment
VariableValue
LANG en_US.UTF-8
NOTIFY_SOCKET /run/systemd/notify
INVOCATION_ID 79fe95a015f04ec8b103a360df444fa4
JOURNAL_STREAM 8:2444877439
SYSTEMD_EXEC_PID 4711
OPENSSL_NO_DEFAULT_ZLIB 1
APACHE_VERSION 2.4.62
CACHE_MEM_LIMIT 10%
DOCKER_EXPOSED_PORT 21,22,25,443,7979,80
OWASP_MODSECURITY_CRS_VERSION 3.3.2
PHP_MAX_EXECUTION_TIME 300
PHP_MEMORY_LIMIT 25%
PHP_MINOR_VERSION 8.1
PHP_VERSION 8.1.30
REDIS_ENABLED FALSE
REDIS_VERSION 6.2.14
WEBROOT /var/www/webroot
MASTER_IP 172.16.108.62
MASTER_ID 36006
MASTER_HOST node36006
PHP Variables
VariableValue
$_COOKIE['handl_ip']18.189.185.63
$_COOKIE['handl_url']https://swift-cut.com/2018/10/5mm-aluminium-45-amps/4/
$_COOKIE['user_agent']Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com)
$_COOKIE['handl_landing_page']https://swift-cut.com/2018/10/5mm-aluminium-45-amps/4
$_COOKIE['handl_ref']https://swift-cut.com/fr/2018/10/5mm-aluminium-45-amps/4
$_COOKIE['HandLtestDomainNameServer']HandLtestDomainValueServer
$_COOKIE['handl_url_base']https://swift-cut.com/2018/10/5mm-aluminium-45-amps/4/
$_COOKIE['organic_source_str']Internal
$_COOKIE['organic_source']https://swift-cut.com/fr/2018/10/5mm-aluminium-45-amps/4
$_COOKIE['handl_original_ref']https://swift-cut.com/fr/2018/10/5mm-aluminium-45-amps/4
$_SERVER['REDIRECT_UNIQUE_ID']Z0D0XR6ANyADrQIM3_C6mAAAAAM
$_SERVER['REDIRECT_HTTPS']on
$_SERVER['REDIRECT_SSL_TLS_SNI']etpsolutions.com
$_SERVER['REDIRECT_STATUS']200
$_SERVER['UNIQUE_ID']Z0D0XR6ANyADrQIM3_C6mAAAAAM
$_SERVER['HTTPS']on
$_SERVER['SSL_TLS_SNI']etpsolutions.com
$_SERVER['HTTP_ACCEPT']*/*
$_SERVER['HTTP_USER_AGENT']Mozilla/5.0 AppleWebKit/537.36 (KHTML, like Gecko; compatible; ClaudeBot/1.0; +claudebot@anthropic.com)
$_SERVER['HTTP_COOKIE']handl_ip=18.189.185.63; handl_url=https%3A%2F%2Fswift-cut.com%2F2018%2F10%2F5mm-aluminium-45-amps%2F4%2F; user_agent=Mozilla%2F5.0%20AppleWebKit%2F537.36%20%28KHTML%2C%20like%20Gecko%3B%20compatible%3B%20ClaudeBot%2F1.0%3B%20%2Bclaudebot%40anthropic.com%29; handl_landing_page=https%3A%2F%2Fswift-cut.com%2F2018%2F10%2F5mm-aluminium-45-amps%2F4; handl_ref=https%3A%2F%2Fswift-cut.com%2Ffr%2F2018%2F10%2F5mm-aluminium-45-amps%2F4; HandLtestDomainNameServer=HandLtestDomainValueServer; handl_url_base=https%3A%2F%2Fswift-cut.com%2F2018%2F10%2F5mm-aluminium-45-amps%2F4%2F; organic_source_str=Internal; organic_source=https%3A%2F%2Fswift-cut.com%2Ffr%2F2018%2F10%2F5mm-aluminium-45-amps%2F4; handl_original_ref=https%3A%2F%2Fswift-cut.com%2Ffr%2F2018%2F10%2F5mm-aluminium-45-amps%2F4
$_SERVER['HTTP_ACCEPT_ENCODING']gzip, br, zstd, deflate
$_SERVER['HTTP_HOST']etpsolutions.com
$_SERVER['PATH']/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
$_SERVER['SERVER_SIGNATURE']no value
$_SERVER['SERVER_SOFTWARE']Apache
$_SERVER['SERVER_NAME']etpsolutions.com
$_SERVER['SERVER_ADDR']95.110.177.123
$_SERVER['SERVER_PORT']443
$_SERVER['REMOTE_ADDR']18.189.185.63
$_SERVER['DOCUMENT_ROOT']/var/www/webroot/ROOT
$_SERVER['REQUEST_SCHEME']https
$_SERVER['CONTEXT_PREFIX']no value
$_SERVER['CONTEXT_DOCUMENT_ROOT']/var/www/webroot/ROOT
$_SERVER['SERVER_ADMIN']admin@etpsolutions.com
$_SERVER['SCRIPT_FILENAME']/var/www/webroot/ROOT/index.php
$_SERVER['REMOTE_PORT']7283
$_SERVER['REDIRECT_URL']/forums/topic/8775-cerco-ori-nuova-fiesta-16-tdci-90cv-fap
$_SERVER['GATEWAY_INTERFACE']CGI/1.1
$_SERVER['SERVER_PROTOCOL']HTTP/1.1
$_SERVER['REQUEST_METHOD']GET
$_SERVER['QUERY_STRING']no value
$_SERVER['REQUEST_URI']/forums/topic/8775-cerco-ori-nuova-fiesta-16-tdci-90cv-fap
$_SERVER['SCRIPT_NAME']/index.php
$_SERVER['PHP_SELF']/index.php
$_SERVER['REQUEST_TIME_FLOAT']1732310109.3878
$_SERVER['REQUEST_TIME']1732310109
$_SERVER['argv']
Array
$_SERVER['argc']0
PHP Credits
PHP Group
Thies C. Arntzen, Stig Bakken, Shane Caraveo, Andi Gutmans, Rasmus Lerdorf, Sam Ruby, Sascha Schumann, Zeev Suraski, Jim Winstead, Andrei Zmievski
Language Design & Concept
Andi Gutmans, Rasmus Lerdorf, Zeev Suraski, Marcus Boerger
PHP Authors
ContributionAuthors
Zend Scripting Language Engine Andi Gutmans, Zeev Suraski, Stanislav Malyshev, Marcus Boerger, Dmitry Stogov, Xinchen Hui, Nikita Popov
Extension Module API Andi Gutmans, Zeev Suraski, Andrei Zmievski
UNIX Build and Modularization Stig Bakken, Sascha Schumann, Jani Taskinen, Peter Kokot
Windows Support Shane Caraveo, Zeev Suraski, Wez Furlong, Pierre-Alain Joye, Anatol Belski, Kalle Sommer Nielsen
Server API (SAPI) Abstraction Layer Andi Gutmans, Shane Caraveo, Zeev Suraski
Streams Abstraction Layer Wez Furlong, Sara Golemon
PHP Data Objects Layer Wez Furlong, Marcus Boerger, Sterling Hughes, George Schlossnagle, Ilia Alshanetsky
Output Handler Zeev Suraski, Thies C. Arntzen, Marcus Boerger, Michael Wallner
Consistent 64 bit support Anthony Ferrara, Anatol Belski
SAPI Modules
ContributionAuthors
Apache 2.0 Handler Ian Holsman, Justin Erenkrantz (based on Apache 2.0 Filter code)
CGI / FastCGI Rasmus Lerdorf, Stig Bakken, Shane Caraveo, Dmitry Stogov
CLI Edin Kadribasic, Marcus Boerger, Johannes Schlueter, Moriyoshi Koizumi, Xinchen Hui
Embed Edin Kadribasic
FastCGI Process Manager Andrei Nigmatulin, dreamcat4, Antony Dovgal, Jerome Loyet
litespeed George Wang
phpdbg Felipe Pena, Joe Watkins, Bob Weinand
Module Authors
ModuleAuthors
BC Math Andi Gutmans
Bzip2 Sterling Hughes
Calendar Shane Caraveo, Colin Viebrock, Hartmut Holzgraefe, Wez Furlong
COM and .Net Wez Furlong
ctype Hartmut Holzgraefe
cURL Sterling Hughes
Date/Time Support Derick Rethans
DB-LIB (MS SQL, Sybase) Wez Furlong, Frank M. Kromann, Adam Baratz
DBA Sascha Schumann, Marcus Boerger
DOM Christian Stocker, Rob Richards, Marcus Boerger
enchant Pierre-Alain Joye, Ilia Alshanetsky
EXIF Rasmus Lerdorf, Marcus Boerger
FFI Dmitry Stogov
fileinfo Ilia Alshanetsky, Pierre Alain Joye, Scott MacVicar, Derick Rethans, Anatol Belski
Firebird driver for PDO Ard Biesheuvel
FTP Stefan Esser, Andrew Skalski
GD imaging Rasmus Lerdorf, Stig Bakken, Jim Winstead, Jouni Ahto, Ilia Alshanetsky, Pierre-Alain Joye, Marcus Boerger, Mark Randall
GetText Alex Plotnick
GNU GMP support Stanislav Malyshev
Iconv Rui Hirokawa, Stig Bakken, Moriyoshi Koizumi
IMAP Rex Logan, Mark Musone, Brian Wang, Kaj-Michael Lang, Antoni Pamies Olive, Rasmus Lerdorf, Andrew Skalski, Chuck Hagenbuch, Daniel R Kalowsky
Input Filter Rasmus Lerdorf, Derick Rethans, Pierre-Alain Joye, Ilia Alshanetsky
Internationalization Ed Batutis, Vladimir Iordanov, Dmitry Lakhtyuk, Stanislav Malyshev, Vadim Savchuk, Kirti Velankar
JSON Jakub Zelenka, Omar Kilani, Scott MacVicar
LDAP Amitay Isaacs, Eric Warnke, Rasmus Lerdorf, Gerrit Thomson, Stig Venaas
LIBXML Christian Stocker, Rob Richards, Marcus Boerger, Wez Furlong, Shane Caraveo
Multibyte String Functions Tsukada Takuya, Rui Hirokawa
MySQL driver for PDO George Schlossnagle, Wez Furlong, Ilia Alshanetsky, Johannes Schlueter
MySQLi Zak Greant, Georg Richter, Andrey Hristov, Ulf Wendel
MySQLnd Andrey Hristov, Ulf Wendel, Georg Richter, Johannes Schlüter
OCI8 Stig Bakken, Thies C. Arntzen, Andy Sautins, David Benson, Maxim Maletsky, Harald Radi, Antony Dovgal, Andi Gutmans, Wez Furlong, Christopher Jones, Oracle Corporation
ODBC driver for PDO Wez Furlong
ODBC Stig Bakken, Andreas Karajannis, Frank M. Kromann, Daniel R. Kalowsky
Opcache Andi Gutmans, Zeev Suraski, Stanislav Malyshev, Dmitry Stogov, Xinchen Hui
OpenSSL Stig Venaas, Wez Furlong, Sascha Kettler, Scott MacVicar, Eliot Lear
Oracle (OCI) driver for PDO Wez Furlong
pcntl Jason Greene, Arnaud Le Blanc
Perl Compatible Regexps Andrei Zmievski
PHP Archive Gregory Beaver, Marcus Boerger
PHP Data Objects Wez Furlong, Marcus Boerger, Sterling Hughes, George Schlossnagle, Ilia Alshanetsky
PHP hash Sara Golemon, Rasmus Lerdorf, Stefan Esser, Michael Wallner, Scott MacVicar
Posix Kristian Koehntopp
PostgreSQL driver for PDO Edin Kadribasic, Ilia Alshanetsky
PostgreSQL Jouni Ahto, Zeev Suraski, Yasuo Ohgaki, Chris Kings-Lynne
Pspell Vlad Krupin
Readline Thies C. Arntzen
Reflection Marcus Boerger, Timm Friebe, George Schlossnagle, Andrei Zmievski, Johannes Schlueter
Sessions Sascha Schumann, Andrei Zmievski
Shared Memory Operations Slava Poliakov, Ilia Alshanetsky
SimpleXML Sterling Hughes, Marcus Boerger, Rob Richards
SNMP Rasmus Lerdorf, Harrie Hazewinkel, Mike Jackson, Steven Lawrance, Johann Hanne, Boris Lytochkin
SOAP Brad Lafountain, Shane Caraveo, Dmitry Stogov
Sockets Chris Vandomelen, Sterling Hughes, Daniel Beulshausen, Jason Greene
Sodium Frank Denis
SPL Marcus Boerger, Etienne Kneuss
SQLite 3.x driver for PDO Wez Furlong
SQLite3 Scott MacVicar, Ilia Alshanetsky, Brad Dewar
System V Message based IPC Wez Furlong
System V Semaphores Tom May
System V Shared Memory Christian Cartus
tidy John Coggeshall, Ilia Alshanetsky
tokenizer Andrei Zmievski, Johannes Schlueter
XML Stig Bakken, Thies C. Arntzen, Sterling Hughes
XMLReader Rob Richards
XMLWriter Rob Richards, Pierre-Alain Joye
XSL Christian Stocker, Rob Richards
Zip Pierre-Alain Joye, Remi Collet
Zlib Rasmus Lerdorf, Stefan Roehrich, Zeev Suraski, Jade Nicoletti, Michael Wallner
PHP Documentation
Authors Mehdi Achour, Friedhelm Betz, Antony Dovgal, Nuno Lopes, Hannes Magnusson, Philip Olson, Georg Richter, Damien Seguy, Jakub Vrana, Adam Harvey
Editor Peter Cowburn
User Note Maintainers Daniel P. Brown, Thiago Henrique Pojda
Other Contributors Previously active authors, editors and other contributors are listed in the manual.
PHP Quality Assurance Team
Ilia Alshanetsky, Joerg Behrens, Antony Dovgal, Stefan Esser, Moriyoshi Koizumi, Magnus Maatta, Sebastian Nohn, Derick Rethans, Melvyn Sopacua, Pierre-Alain Joye, Dmitry Stogov, Felipe Pena, David Soria Parra, Stanislav Malyshev, Julien Pauli, Stephen Zarkos, Anatol Belski, Remi Collet, Ferenc Kovacs
Websites and Infrastructure team
PHP Websites Team Rasmus Lerdorf, Hannes Magnusson, Philip Olson, Lukas Kahwe Smith, Pierre-Alain Joye, Kalle Sommer Nielsen, Peter Cowburn, Adam Harvey, Ferenc Kovacs, Levi Morrison
Event Maintainers Damien Seguy, Daniel P. Brown
Network Infrastructure Daniel P. Brown
Windows Infrastructure Alex Schoenmaker
PHP License
This program is free software; you can redistribute it and/or modify it under the terms of the PHP License as published by the PHP Group and included in the distribution in the file: LICENSE
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
If you did not receive a copy of the PHP license, or have any questions about PHP licensing, please contact license@php.net.
