Ospite stabia83 Inviato 14 Dicembre 2009 Inviato 14 Dicembre 2009 audi 3 140 cv tdi errori sono 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Sporadic communication error 1000 03-ABS Brakes -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 62-Door,Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 7D-Aux. Heat -- Status: OK 0000 nel dettaglio Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.LBL Part No: 1K0 907 379 K Component: ESP FRONT MK60 0104 Coding: 0023174 Shop #: WSC 06435 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermitten Address 09: Cent. Elect. Labels: 8P0-907-279.LBL Part No SW: 8P0 907 279 C HW: 8P0 907 279 C Component: Bordnetz-SG H34 0301 Coding: 03884F029214100000160000160000000000FE0F5C Shop #: WSC 00000 Part No: 1K1 955 119 A Component: Wischer VW350 011 0301 Coding: 00065493 Shop #: WSC 00000 3 Faults Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent 02498 - Left Low Beam Reflector Motor (V294) 012 - Electrical Fault in Circuit 02499 - Right Low Beam Reflector Motor (V295) 012 - Electrical Fault in Circuit Address 19: CAN Gateway Labels: 1K0-907-530.LBL Part No SW: 1K0 907 530 D HW: 1K0 907 951 Component: Gateway H08 0100 Coding: 3D3F0B00072102 Shop #: WSC 06314 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 8 Reset counter: 65 Mileage: 85274 km Time Indication: 0 Date: 2009.10.25 Time: 22:19:54 Address 44: Steering Assist Labels: 1Kx-909-14x.LBL Part No: 1K1 909 144 G Component: EPS_ZFLS Kl.10 1401 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Mileage: 5240 km Temperature: 20.0°C Voltage: 12.50 V Voltage: 12.30 V grazie ki spiega ke errori sono ?..
Ospite Inviato 15 Dicembre 2009 Inviato 15 Dicembre 2009 Dove c'è scritto STATUS OK...non sono errori. Gli errori sono dove hai MALFUNCTION
antonelllo Inviato 15 Dicembre 2009 Inviato 15 Dicembre 2009 ciao...inserisci i codici di errore nella pagina che si aprirà seguendo questo link.poi traduci la pagina e potrai capirci qualcosina in piùà http://wiki.ross-tech.com/index.php/Main_Page
Ospite stabia83 Inviato 15 Dicembre 2009 Inviato 15 Dicembre 2009 ora controllo su quel sito cmq l'avevo capito ke status ok era tutto apposto vi ringrazio...vi faccio sapere puo servire a qualcun'altro...
Ospite stabia83 Inviato 15 Dicembre 2009 Inviato 15 Dicembre 2009 sono andato sul sito ma nn mi fa la traduzione di quelle parole...boo
supertm Inviato 15 Dicembre 2009 Inviato 15 Dicembre 2009 controlla il rele frecie e sostituisci l'interuttore pedale freno dovresti avere la spia abs accesa
Ospite stabia83 Inviato 15 Dicembre 2009 Inviato 15 Dicembre 2009 e dove si trova? hiihihi cmq grazie della risposta nn so qual'e ti sarei tanto grado di dirmi dove si trova....grazieee
supertm Inviato 16 Dicembre 2009 Inviato 16 Dicembre 2009 il rele e il primo a dx in alto il sensore e sul pedale freno basta che togli la copertura inferiore
Ospite stabia83 Inviato 16 Dicembre 2009 Inviato 16 Dicembre 2009 come faccio a vedere se il rele e buono e cmq nn ho capito dove si trova ?
supertm Inviato 17 Dicembre 2009 Inviato 17 Dicembre 2009 sotto dove hai tutti i rele ei fusibili sotto lo sterzo cmq meglio che la porti da un eletrauto fai danno non ti vedo bene come riparatore
Ospite stabia83 Inviato 17 Dicembre 2009 Inviato 17 Dicembre 2009 qualcosa ne capisco di elettronica ...si puo vedere se un rele e buono ho cpito dove stanno l'avro smontato 20 30 volte il pezzo sotto lo sterzo ....x fare l'impianto ecc... come si fa a vedere se funziona il rele?ti ringrazio
zani70 Inviato 4 Marzo 2010 Inviato 4 Marzo 2010 Codice VAG 01314 -Centralina di controlo motore,sistema di programatore velocita di crociera -funzionamento difettoso. Causa probabile-Centralina di controlo motore. O forse rimapata?????vedi tu.
Ospite marins Inviato 4 Marzo 2010 Inviato 4 Marzo 2010 si l'auto e rimappata il cruise control nn lo tengo....e qualke centralina piccola da cambiare?ciao e grazie
Ospite Inviato 7 Maggio 2010 Inviato 7 Maggio 2010 pensa ke dopo la riprogrammazione seriale su queste auto vengono memorizzati sempre gli errori sulla centralina 1 e 3 per mancata comunicazione quindi resetta e vedi ke non te li darà +
Ospite Inviato 7 Ottobre 2010 Inviato 7 Ottobre 2010 secondo me relè e pedale freno non sono, anche perchè se fossero, lo dice con altri due specifici errori.è più probabile fossero li dalla riprogrammazione quegli errori...o hanno abilitato il cruiser ma mancando levetta e tutto ilresto...da errore per forza....
Ospite stabia83 Inviato 21 Febbraio 2013 Inviato 21 Febbraio 2013 Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.LBLPart No: 1K0 907 379 KComponent: ESP FRONT MK60 0104Coding: 0023174Shop #: WSC 064351 Fault Found:01314 - Engine Control Module 004 - No Signal/Communication - Intermitten ho capito na che mi si accende la spia esp dopo 10 minuti sempre dopo 10 minuti ache se sto fermo 10 minuti in parcheggio per questo errore perche quando mi esce a spia accesa se cancello questo errore si spegne la spia cosa puo essere grazie
